Will shock dampening change when going from 7w to 5w oil?
Discussion in 'Performance and Tuning' started by crhsharks12, Oct 27, 2020.
  1. Oct 27, 2020 at 8:20 AM
    crhsharks12
    crhsharks12 [OP] Well-Known Member
    Denver, CO
    ‘06 Tacoma 4WD TRD Sport DCSB 4.0L V6
    RR 2.5 King shocks front/rear, Camburg UCA's, Icon AAL Springs Softopper & BA Bumper
    I was curious as to whether changing from 7w to 5w oil would significantly change the dampening of the shock. What would occur internally if the oils were switched? Would a thinner oil cause quicker rebound and compression, or even enough to make a difference? Would it reduce the life of the shock, or increase temperature inside?
    For reference, I have Icon 2.5 CO.
  2. Oct 27, 2020 at 5:03 PM
    theturbodog
    theturbodog Well-Known Member
    Fort Worth, TX
    I'm not sure on your exact combination, but technically the answer is yes. Back when i was racing motorcycles we used slight changes in shock oils all the time to slightly adjust dampening curves. That being said I'm not sure if a 2w change on the truck shock will be at all noticeable even if it is technically different. I don't know of any differences in shock life if it's the same basic oil formula(seal compatibility). I would actually expect temps to be slightly lower with the lower viscosity since it would slip through the shim stack or orifices easier, but again maybe not practically enough to be noticeable.
    crhsharks12[OP] likes this.
  3. Oct 27, 2020 at 8:18 PM
    crhsharks12
    Denver, CO
    right, fair fair.
  4. Oct 27, 2020 at 8:22 PM
    wilson23
    wilson23 Well-Known Member
    in terms of percentages thats a large change
  5. Oct 27, 2020 at 8:32 PM
    crhsharks12
    Denver, CO
    and so, what are you saying?
  6. Oct 27, 2020 at 9:06 PM
    wilson23
    in theory you can expect a 21% reduction in viscosity
  7. Oct 27, 2020 at 9:15 PM
    crhsharks12
    Denver, CO
    ah, and that will help with?
    Will it smoothen out a ride at lower speeds? Will it cause signifiant temperature change?
  8. Oct 28, 2020 at 10:05 AM
    wilson23
    What are you trying to accomplish?
  9. Oct 28, 2020 at 12:32 PM
    crhsharks12
    Denver, CO
    Was hoping/thinking, that a thinner oil would be able to slip through falling faster enough to provide slightly more shock compression at lower speeds, making a large bump, or small bump, less jarring.
    I was also curious as to whether or not a thinner oil (5w) would have less of a life span than thicker oil (7w).
  10. Oct 29, 2020 at 8:24 PM
    wilson23
    Yes, but this will change both compression and rebound characteristics. Since you are opening the shock anyway it would be quite simple to just do a quick valve change to only effect compression damping. I dont see an issue with shock life, I say go for it.
  11. Oct 29, 2020 at 9:56 PM
    crhsharks12
    Denver, CO
    Right, but isn’t quicker rebound better anyways?
    I was thinking About messing with the valving, but I don’t really know how to go about doing it, ya know?
  12. Oct 30, 2020 at 11:32 AM
    wilson23
    You should probably do some research on basic suspension theory
  13. Oct 30, 2020 at 11:38 AM
    crhsharks12
    Denver, CO
    I just realized what I said doesn’t always apply and make sense. Quicker rebound is less controlled and you don’t want your rear end to shoot up, want to keep it planted.
  14. Nov 2, 2020 at 6:21 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    You will barely notice. It will drop shock forces slightly across the board. Thinner oils tend to have a less drastic cold to hot viscosity change so less damping change with temperature but this is also oil specific. And it's damping.
