Will stock speakers handle 100w amp?
Discussion in 'Audio & Video' started by Jwest336, Oct 6, 2020.
  1. Oct 6, 2020 at 9:03 PM
    Jwest336
    Jwest336 [OP] New Member
    Jeremy
    2004 Black Tacoma Prerunner
    2004 tacoma ext. cab. factory door speakers be able to handle 100 watt rms amplifier?
  2. Oct 7, 2020 at 4:22 AM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    25W each? Sure...if they aren't rotted already.
    100W each? Probably not.
    Purpleman likes this.
  3. Oct 7, 2020 at 9:12 PM
    Jwest336
    Jeremy
    Ok. Thanks Rob for your feedback. Idk if Toyota has 25w or 100w factory installed door speakers? Guess I'll do some more research.
  4. Oct 8, 2020 at 3:36 AM
    rob feature
    rob feature Tacos!
    Colorado
    I'm in the middle of moving and will pull one out of a box here before too long. Pretty sure the power rating is stamped on the back. I can tell you with a good degree of certainty they won't handle much more than head unit power though. That's to say I wouldn't feed a single driver more than 25W and expect it to last more than a few minutes. It's a basic, low travel, high efficiency driver.
  5. Oct 8, 2020 at 3:39 AM
    rob feature
    rob feature Tacos!
    Colorado
    Found a couple pics
    20W
    Made in USA believe it or not!
  6. Oct 8, 2020 at 3:50 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Yeah if the cone on your ‘04 speaker is still in one piece, feeding it 25w RMS will change that pretty quickly. The foam surround will turn to dust pretty quickly from what I’ve seen.
    Once you get new speakers, hook up your amp to your old speakers and see how much they can handle before they start smoking or seize up :D
    JimResnikoff likes this.
  7. Oct 8, 2020 at 8:02 PM
    Jwest336
    Jeremy
    Thanks guys. I have a pair of Sony 1000 watt subs in a box behind seat, amp is 600 watts. I don't need more bass, it is overpowering the music, so I have another amp for mids and highs, but I will just wait to hook it up until I get new door speakers. I will try that experiment destin, good idea. Thanks again Rob, saved me from doing some research.
  8. Oct 10, 2020 at 4:41 PM
    JimResnikoff
    JimResnikoff Well-Known Member
    JIm
    Tacoma
    Rockford / Focal Audio upgrade
    possibly for a brief moment.
