will switching brands eliminate vibration
Discussion in 'Suspension' started by Iluvtacos, Dec 4, 2010.
  1. Dec 4, 2010 at 6:04 PM
    Iluvtacos
    Iluvtacos [OP] Active Member
    Rich
    Rock Hill, SC
    07 trd sport 4x4
    6" procomp lift, grillecraft grille, painted vent shades, 33" procomp extreme AT tires, Moto Metal wheels, Fabtech side steps, Shocker classic train horn, about ten more things which I can't remember
    :confused:I have that pesky vibration since I put a 3" pro comp spacer lift w/ AAL on. What if I throw out this lift all together and try... say...the 3" toytec ultimate lift, will I still have that 'f---in' vibration? Or is this a problem I will have no matter what lift I use? What if I went to a 6"?
    By the way I removed the front drive shaft today and no change in the vibration. Its gotta be the front diff or cv's. Truck is an 07 with just around 38k miles. I can't believe these would be shot already. Warrenty has passed also
  2. Dec 4, 2010 at 10:33 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I would bet its your drive line. Try some 3* shims in the rear, then go from there.
    Most vibes after lifting come from the drive shaft/carrier bearing. So I would try the shims first before tossing the lift...
  3. Dec 5, 2010 at 6:07 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Changing lifts won't change the vibration. The vibration is most likely coming from the rear driveshaft.
    As Evertaco23 has already said, put some axle shims in and that should help.
  4. Dec 5, 2010 at 8:03 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    It might work....It might not to swap the lift components....but starting with the shims is a good place. You can try a diff drop too. Those are cheaper than buying a while new lift...(60 bucks or so compared to a 700ish)
  5. Dec 5, 2010 at 11:54 AM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    What they all said. Try shims first. No matter what lift you run up front your going to change the angle of the drive shaft which is probably whats causing your vibrations. Thats assuming that you feel the vibrations in the seat. If you feel the vibrations in the steering wheel, you need to get your alignment checked out.
