Will Tacoma's suffer the same engine failure fate as the Tundra?
Discussion in '4th Gen. Tacomas (2024+)' started by Sig Taco, May 31, 2024.
  1. Jun 24, 2024 at 7:39 AM
    #161
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    This article made me chuckle “the price of a trd pro tacoma goes up to nearly $50000”
    batacoma[QUOTED] likes this.
  2. Jun 24, 2024 at 8:00 AM
    #162
    Digitalwiz5
    Digitalwiz5 Well-Known Member
    I don’t take JD or CR as creditable sources of consumer info anymore. I mean JD seems to rotate through manufacturers, like motor trend for who’s best. CR on the other hand is usually blind to Toyota’s issues and seem to favor them over the competition all the time. The recent CR take on the tundra is surprising, but they usually trash everything else so we’ll see if maybe they are changing their stripes.
    I tend to agree with some here who have said that Toyota is blaming machining debris because the alternatives make them look way worse.
    batacoma, Mad German and SH10151 like this.
  3. Jun 24, 2024 at 8:26 AM
    #163
    maxmk8
    Was it cam or was it crank ? Since it seems to be a bottom end issue I thought.
    batacoma likes this.
  4. Jun 24, 2024 at 8:27 AM
    #164
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    CR has been trash since they rigged the Samurai and Trooper rollover/evasion tests.
  5. Jun 24, 2024 at 8:43 AM
    #165
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    They are not credible in my book, I'm not even sure what they are and what value they offer to the consumer?
    They aren't historically Toyota cheerleaders by any means. They have been giving the new Tundra a low grade since it's release, and with the Tundra's issues this has given CR and JD some validation in this regard.
  6. Jun 24, 2024 at 9:26 AM
    #166
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    Thought it was an oil starvation issue and a cam design with the main bearing. Let me see if I can find the video talking about it.
  7. Jun 24, 2024 at 9:34 AM
    #167
    maxmk8
    You’re saying everything right minus the cam/crank part IIRC. Main bearings are not on cams.
  8. Jun 24, 2024 at 9:46 AM
    #168
    TacoBuffet
    AL
    Yep I know, separate areas, pieces. He talked about it (main bearing issue) and he said the cam design too, trying to find the video for you, hes a toyota tech.
  9. Jun 24, 2024 at 9:52 AM
    #169
    Mad German
    Mad German Well-Known Member
    2016 TRD Off Road
    I always thought of CR as being big Toyota cheerleaders. At least in the past, when I read CR. But it's been several years since I looked at it for anything car/truck related.
  10. Jun 24, 2024 at 10:46 AM
    #170
    turkeyslayer66
    turkeyslayer66 Well-Known Member
    mike
    22 AG Trd Sport
    well, debris left in an oil galley could certainly cause an oil starvation issue, especially at idle with the lower oil pressures all these new engines seem to run at. Really liked these new Tundras, hope they get it figured out and fixed for folks. Really crappy situation to be in for sure.
  11. Jun 24, 2024 at 1:00 PM
    #171
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    Indeed. I am skeptical of the debris theory for our Tundras. First, the problem is the same bearing in every case. What Toyota is saying is that this debris is magically positioned so that it goes straight to that bearing, and only that bearing, and doesn't clog the oil passages which would cause starvation, but instead gets captured in said bearing and gradually cause it to deteriorate over time, hence the failures past 20k miles. I don't buy it personally. Seems if there were significant debris it would clog oil passages and cause quicker failures.
    TacoBuffet and TurboDA6 like this.
  12. Jun 24, 2024 at 4:52 PM
    #172
    TurboDA6
    TurboDA6 Well-Known Member
    I agree.
    Toyota is only replacing the short block, meaning (hopefully) they are confident metal debris isn't circulating around the engine. I just can't see debris getting into the same one bearing, and not creating collateral damage elsewhere.
  13. Jun 25, 2024 at 1:37 PM
    #173
    Raylo
    MD, USA
    Actually, we don't know exactly what Toyota is going to do yet. They had been replacing short blocks as they failed but the new safety recall covers ~100,000 Tundras... with maybe more to be added later since the failures are mostly happening after 20k miles... and it says that Toyota is still developing the remedy to address all affected vehicles and that won't be made public until sometime in July. Being that is it a safety recall they will need a positive way to fix or otherwise ensure that all the affected vehicles are safe. It might even mean all new engines replaced pre-emptively. We'll see.
    Meanwhile many of us are having second thoughts of taking long road trips.
  14. Jun 25, 2024 at 2:16 PM
    #174
    PDKTaco
    PDKTaco Well-Known Member
    Montana
    2024 TRD Off-road
    If it’s circulating the filter would catch it. If the debris is in the oil passages it’s likely going to the bearings on initial start up creating a time bomb.
  15. Jun 25, 2024 at 6:13 PM
    #175
    pinem56
    pinem56 Well-Known Member
    NE
    2018 TRDOR DCSB AT
    It really is bad. I've read that not only is the GX 550 having the same problems, but also the LC 300 too. So basically every vehicle using this motor across the world is now a hot potato. I had also read the motor is manufactured in both Alabama and Japan, and failures are coming out of both factories, so it has to be a design issue. Even repaired motors are failing. I'd say CAFE is mostly to blame, but then Toyota has had a miserable record of producing fuel efficient truck motors too, it's like their engineers can't even fathom how to design a fuel efficient motor for trucks.
  16. Jun 25, 2024 at 6:25 PM
    #176
    soupy1234
    soupy1234 Well-Known Member
    2024 Celestial Silver TRD OR LB
    I can see it. This is, of course, conjecture, but if the problem was with whatever automated system they use to flush the blocks after machining, it could very well miss the same spot on every block.
  17. Jun 27, 2024 at 2:06 PM
    #177
    LEBM
    LEBM Thread Killer
    Eleanor, WV
    2021 TRD PRO 6MT Midnight Black
    Canadian Caber, Mudc4t and PDKTaco like this.
  18. Jun 28, 2024 at 4:52 PM
    #178
    TurboDA6
    He's great.
    And I reached the same conclusion as him: short block replacement bad. That's what Toyota has been doing until now.
    If they long block/partial assembly swap for the recall, that'll probably disappoint all who've had the short block done already....... just not right on such a complicated engine
    LEBM[QUOTED] likes this.
  19. Jun 28, 2024 at 9:44 PM
    #179
    Digitalwiz5
    Yes, but I mean, let’s dive right in, and then let’s reiterate from earlier and dive in some more and when we’re done, we’ll dive in.
  20. Jun 29, 2024 at 6:48 AM
    #180
    maxmk8
