Will tails from a 98 fit a 02?
Discussion in '1st Gen. Tacomas (1995-2004)' started by toy02ota, May 24, 2010.
  1. May 24, 2010 at 1:58 PM
    toy02ota
    toy02ota [OP] Local TW dissenter
    Brownsville, TN
    2005 Chevy Silverado
    A guy down the road is selling some euros from his 98. Will they fit my 02 model?
  2. May 24, 2010 at 2:12 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    i think so.. not positive though.. somebody correct me if im wrong
  3. May 24, 2010 at 2:56 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    I would say yes...I think Toyota only added a front facelift and crewcab 01 :cool:
  4. May 24, 2010 at 2:58 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    They will physically fit up, but they won't work right. The grounding scheme changed in 2001.
  5. May 24, 2010 at 3:08 PM
    SixtyDashOne
    SixtyDashOne Well-Known Member
    Collegeville, PA
    2021 ArmyGreen TRD Sport, 2007 Regular Cab 4x4
    Im 99% sure that you can use the wiring harness off of the 02, and they will snap into the 98's
    As far as the phisical dimensions; identical...
  6. May 24, 2010 at 3:10 PM
    98_Mud_bug
    lucedale Ms.
    that shouldnt matter.. you take the bulbs out of one tail light and put them in the other one.. then screw it back to the truck..
  7. May 24, 2010 at 5:21 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    i just swapped some from 02 to my 98... 98 to 02 doesnt work right tho...
  8. May 24, 2010 at 5:29 PM
    SixtyDashOne
    Collegeville, PA
    even when using the 02 harness? ^^
  9. May 24, 2010 at 6:03 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    u mean swap over the bulbs and little wiring harness from one housing to the other? probly will work...
  10. May 24, 2010 at 6:34 PM
    SixtyDashOne
    Collegeville, PA
    yes, as i believe they will twist right in..
    I remember i bought a set off of an 04, and they fit on my 00, and they came with the 04 harness, and they were different.. But i removed them and used my 00 harness. so i cant see it being a problem to swap them the opposite way.
  11. May 24, 2010 at 6:44 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    yeah ur probly right on the dot. i just simply swapped complete housings over and my connectors just dont use one of the pins on the newer tail lights...
