Will the 2015 TPMS work on a 2016 Wheel?
Discussion in 'Wheels & Tires' started by 03coma, Nov 20, 2015.
  1. Nov 20, 2015 at 11:07 AM
    03coma
    03coma [OP] Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    Hey Guys I'm getting conflicting info. from Toyota about the TPMS in a 2015 TRD Alloy rim (PN 42611-AD031) I want to install the TPMS into the 2016 (PN. 42611-04150) Machined Contrast Alloy Wheel.
    I know the Part Number for the TPMS on the 2015 is 42607-06011 but will it work for the 2016 rim? Anyone have any experience or info on this matter? Toyota says it might fit, I can give you a case number. not much help when you have your tires off the oem rims and the TPMS does not fit.
  2. Nov 20, 2015 at 11:51 AM
    Brianz1001
    Brianz1001 Well-Known Member
    Brian
    Retired on my couch with a cold beer in my hand
    too much to type
    ok let me get this straight, you have the AD031's on a 2015 tacoma and want to install the 2016 04150 rims using the 2015 TPMS. I believe they would work. The angle if I'm correct is the 45 on that sensor. the 20 is used on the steel wheels. Anyone chime in if i'm giving incorrect info.
  3. Nov 20, 2015 at 2:31 PM
    jprice07
    jprice07 New Member
    Calgary
    2016 Toyota Tacoma TRD Double Cab
    Stock... for now.
    Hey... just put the winters from my 2014 Tacoma on my 2016 and I'll need to reprogram for sure. Nothing registers for tire pressure in the display and the Yellow TPMS light comes on in the cluster, off to the dealer next week... will update then.
