Will the 5' bed hold an ATV
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crimsonfurious, Feb 19, 2016.
  1. Feb 19, 2016 at 8:17 AM
    Crimsonfurious
    Crimsonfurious [OP] Well-Known Member
    2014 Tacoma XP
    I'm buying a 4wheeler this weekend and i'm thinking it should fit in the back of my truck (might need to lay the tailgate down) but does anyone out there have a 5' bed and know for sure if they can accommodate most ATV's in the bed or would i need to buy a trailer?
  2. Feb 19, 2016 at 8:30 AM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    I have fit a blaster, ltz400 and my Honda 450r all with the tailgate down. The Honda needed to go up over the wheel wells because of how wide it is but all of them fit. Just lay the gate down and strap them tight. If it's a 4x4 quad and really big you may have some more difficulty.
  3. Feb 19, 2016 at 10:01 AM
    BlueHeli
    BlueHeli Well-Known Member
    AZ
    2017 Quicksand TRD OFFROAD 6MT
    None
    Well I'm glad I found this. Now I have a reason to get rid of my tonneau cover.
  4. Feb 19, 2016 at 10:35 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    My Polaris will not fit between the fender wells. Keep the tonneau and buy a trailer. After loading my Polaris in my F150 a couple of times that is what I did. So much easier and I have the bed for other stuff.
  5. Feb 19, 2016 at 10:40 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
  6. Feb 19, 2016 at 11:23 AM
    Crimsonfurious
    2014 Tacoma XP
    thanks for the input, especially the photos. I'm buying a Honda Rancher (utility) so hopefully not as long as a sport. i do have a tonneau but im hoping not to have to remove it as it does fold all the way up against the cab. I have some ratchets so if it hangs off slightly, it shouldnt be a huge deal but we'll see. thanks
  7. Feb 19, 2016 at 11:25 AM
    Crimsonfurious
    2014 Tacoma XP
    mine is a 4x4 by the way which may cause more problems however it is a little older of a model. ill keep yall updated
  8. Feb 19, 2016 at 12:44 PM
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    I load up all the time with a Honda Foreman 500 in a 6' box. To give you an idea I'm just a touch too long to close my tailgate. All of the rear wheel weight is still in the box for me but the furthest sticking out part of the tire is enough so I can't get my gate 100% up.
    The rancher (420?) will be a bit smaller but with a 5' box it's pretty unlikely you will be shutting the gate either. Will it fit though, I bet it will maybe with some of the rear tires resting on the gate.
  9. Feb 19, 2016 at 12:46 PM
    HAVVOKK
    HAVVOKK Well-Known Member
    2014 DGAF Long Bed
    Fucking look it up
    I've put a quad and a dirtbike in the back of my 6 foot bed. I've also put a quad and 2 dirt bikes in the back but you have to get crafty with that
  10. Feb 19, 2016 at 1:49 PM
    SJC3081
    SJC3081 Well-Known Member
    Wappinger NY
    2011 DCLB 4x4
    Please buy a BackRack safety rack or you will bust out your rear window like I did twice in a month.
  11. Feb 19, 2016 at 1:59 PM
    SJC3081
    Wappinger NY
    2011 DCLB 4x4
    I have a CanAm Outlander 800RXT and the front bumper clears the bed and smashes the rear window.
    1buzzbait likes this.
  12. Feb 19, 2016 at 3:16 PM
    devkurf
    devkurf Member at Large
    midwest
    I need to see this :hattip:
  13. Feb 19, 2016 at 3:18 PM
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
  14. Feb 19, 2016 at 3:20 PM
    04trd
    04trd Well-Known Member
    Cleveland Ohio
    2015 f150 lariat
    weather techs, 20precent tint, leveling kit, back flip bed cover, rhino liner
    Here's a dumb thought. A 4x4 Atv is a ton of weight on the cheap tailgate. I've always hated doing it that way. So I ended up going to tractor supply and spending 800 bucks for a 5 foot wide by 9 foot long trailer. Or something close to those dimensions, all I know is it's bigger than a full sheet of plywood. And I threw my Atv on there. It was super nice having the bed for all the muddy clothes. If the Atv was in the back you would be screwed for storing muddy gear
    Also like others have said I would hate to bust out that class cause a 4x4 winch came threw my glass or a bumper
  15. Feb 19, 2016 at 3:20 PM
    RedRed
    RedRed TACO TUESDAY!!!
    Red
    Lake Norman NC
    15 taco with stuff & things
    1.75" Billy's plus 1/4 spacer on both sides. 1" block in rear. 265/70/17 nitto g2 SCS matte dark bronze 6s
    My 2007 trx 450r fits but it sits on top of the fender humps.
  16. Feb 19, 2016 at 3:21 PM
    devkurf
    midwest
    Here is a Honda Rancher in a 6ft bed for comparison. It stops just before the tailgate, but there isnt room to shut it. I lose about 4 inches in the front from the roll up tonneau, but that helps give a cushion between the front guard and the back glass.
  17. Feb 19, 2016 at 3:29 PM
    HAVVOKK
    2014 DGAF Long Bed
    Fucking look it up
    It was a bitch and took alot of tie downs and planning but we made it happen. You put quad in first on its rear tires like doing a wheely, then you bring the bikes in. Have to pick up and shove the front tire next to the tire of the quad in between the wheel well on each side. Then tie down tie down tie down and bam done
  18. Feb 19, 2016 at 3:30 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    I have the outlander 1000xt and wouldn't even think of putting that in the bed. Too heavy and wide with after market wheels.
  19. Feb 22, 2016 at 11:32 AM
    Crimsonfurious
    2014 Tacoma XP
    turns out i didnt buy the rancher 4x4. it was too beat up and rusty for the price so im going to keep looking but this all helps a ton as i wouldnt even have thought of breaking the glass.
  20. Feb 22, 2016 at 12:14 PM
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    I've used one of these for years and they actually work perfect for not smashing your window out. In combination with straps of course. Although really any sort of wheel block will work.
