Will the composite bed stand up to throwing firewood in?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SonOfEru, Feb 9, 2023.
  1. Feb 11, 2023 at 6:45 AM
    #61
    jaxyaks
    jaxyaks Well-Known Member
    2020 Silver Tacoma TRD Off Road
    MarX likes this.
  2. Feb 11, 2023 at 6:48 AM
    #62
    MarX
    MarX Hotdogs, spam and skittles.
    Mark
    NE Kansas
    2013 DCLB Tacoma TRD sorta Sport 4X4, 2009 Tundra SR5 workhorse
    RETRAX bed cover, Tailgate lock, TRD exhaust. 887's, LR UCA'S, Bilstein 5100's and Deavers AAL.
    My 13 has been fine to handle all the abuse. Stay within truck capabilities and it’ll be fine as far as the composite bed goes. Mat helps to keep things from sliding. Also a negative as it won’t slide when you want it to lol. I’ve done way crazier than below pic but all within trucks abilities. Tacomas are tough and durable. Be smart, use within capacity specified and maintain it and it’ll take care of you.
  3. Feb 11, 2023 at 7:03 AM
    #63
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    I have hauled hundreds of cords of firewood over the last 15 years in both of my Tacomas . It can absolutely handle the job without hesitation. Also, fyi, the 6’ bed along with a bed extender will hold 64cf (1/2 cord) of neatly stacked firewood . You will have to crown the load (higher in the middle) but it will do it safely and haul it no problem. Wet oak weighs more then seasoned ash, so payloads vary, but the composite bed has never let me down and can take quite a beating.
    I also occasionally use Toyota’s steel cargo divider and invert it so it protects most of the back glass . I have shattered a window when loading carelessly.
    MarX likes this.
  4. Feb 11, 2023 at 7:15 AM
    #64
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I've had no issues either, (just have to be a little careful around the plug hinge). A Mat is a must!
    MarX likes this.
  5. Feb 11, 2023 at 7:49 AM
    #65
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    My brother- in-law built a vertical "headache panel" out of plywood that he stands up at the front of the bed. Just a temporary window protector to keep his boys from ventilating the cab. Dunno how he held it to the front wall of the bed - will have to ask. Flat and easy to store - I've seen it in there when hauling but never checked it out.
    MarX likes this.
  6. Feb 11, 2023 at 10:26 AM
    #66
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    How much wood can you fit in the back of a 5 ft bed if its stacked? about a face cord?
    MarX likes this.
  7. Feb 11, 2023 at 5:41 PM
    #67
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    Looks like white pine on the tailgate.
  8. Feb 12, 2023 at 4:52 PM
    #68
    BeachBum2012
    BeachBum2012 Well-Known Member
    Brian
    Downey, Ca
    2018 Tacoma TRD OR DCLB
    A bunch of shit...
    Not sure. After looking at the dimensions it looks like it might fit. A half cord sits about a foot to 18" above the bed rails when stacked very carefully in my long bed. Seems like half that should fit in the short bed.
  9. Feb 12, 2023 at 4:58 PM
    #69
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Put a piece of plywood across the front of the bed and stack a couple rows to hold it in place, cheap headache rack to prevent your rear window from breaking if you have a piece bounce up. Another piece on the bed floor will help prevent scratching if that worries you.
    Otherwise, the bed can handle it.
    Chew likes this.
  10. Feb 12, 2023 at 5:04 PM
    #70
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Its a truck with a box on the back that is tough and durable. Just use it.
  11. Feb 13, 2023 at 5:40 PM
    #71
    Williston
    Williston Unknown Member
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    I used my truck to move a felled and cut-up tree to another location on my property. I didn't baby it when I was loading the bed, but I didn't toss them in from six feet awy with height either. I wouldn't do that to my son's F150, never mind my own truck. I was more worried when I loaded the old, cut-up pressure-treated kid's swing-set with the various metal brackets, and heavy 2x6 and 8's (and Carpenter ants: hate 'em!) with the lag screws etc to take it to the dump/transfer station. The bed was fine. The only problem/near disaster I had was when some %$$@^# drove behind behind me at speed as I backed up, and when I hit the brakes I almost "auto un-loaded" the payload in the middle of the parking lot: No bed mat. The attendant threw him out of the place: Justice! (I have a bed-mat now):rolleyes:
    My other son has a 2005 AC LB: 18 years: Some scratching, No sun-fading, no warping, no holes, no color change: no nothing. (except for the two side cubby boxes over the wheel-wells: they took flight at some point and were never seen again.) :facepalm:
    Canadian Caber likes this.
  12. Feb 13, 2023 at 6:07 PM
    #72
    MountainMike68
    MountainMike68 Well-Known Member
    55°N
    2016 TRD Sport AC/MT
    Rather than the bedmat I put in a quarter inch sheet of plywood. It and the bed have held up to tree stumps concrete rubble. Even exceeded payload doing it a few times. I think you'll be fine with cords.
    Williston and CTtoNoVa like this.
  13. Feb 14, 2023 at 6:57 PM
    #73
    Williston
    My son put a piece of plywood in the bed (aluminum) of his F150 a few months after he bought it.... more to keep down the scratching than anything else. There's no dents or dings in it at all, and he cuts his own firewood and transports it in the bed all the time. The weight of the bed mat in my truck smooths out the ride a little and I really think it cuts down on some of the road noise as well.
  14. Feb 15, 2023 at 6:46 AM
    #74
    GREENBIRD56
    Casper / Tucson
    014 Taco 4Dr 4wd
    My big bitch with the Taco bed is the lack of stake pockets........... How do you build a decent "pig fence" on there with nothing sturdy to attach to?
  15. Feb 15, 2023 at 9:08 AM
    #75
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga Strong Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    That’s right! About an hour to an hour and an half away from little ‘ol L.A. Oh wait, you prefer desert? Ocean? We got it all.
    Angeles National Forest allows it for about a $25 permit for soft wood, and a bit more for hardwood, which is usually blue oak or me fave, canyon oak. Best part, one gets the keys to the gate(s):spy:
    TireFire[QUOTED] and TAZMINATOR like this.
  16. Feb 15, 2023 at 9:17 AM
    #76
    Topanga Taco
    Rick
    Yes, permit, only I. Designated areas, return of key (big blow to the pocket if you loose it!) They really don’t monitor the load count in Angeles that well. But that’s on one’s conscious.
    I like the way the forest service up in Kennedy Meadows (about an 3 1/2 hour drive from here) allows felling, with rules, but felling nonetheless. I was hard core into wheeling for wood when I had my 2012 OR and getting permits in Porterville as well! Feels awesome cutting wood near a Taco using a Husky :0)
    TAZMINATOR[QUOTED] likes this.
  17. Feb 15, 2023 at 9:23 AM
    #77
    Topanga Taco
    Rick
    NEVER IN MY NECK OF THE WOODS!
    Fast Huskies for life.
    Custom head for a 3120FP worksaw. Yes folks, worksaw pulling long bars.
  18. Feb 15, 2023 at 9:35 AM
    #78
    Topanga Taco
    Rick
    And a big shout out to Mr. George Harrison from Grass Valley, CA! Who by the way drives a 2016 OR!
    Laters!
  19. Feb 15, 2023 at 9:42 AM
    #79
    Topanga Taco
    Rick
    This is the craziest thing I ever did. I can’t believe that’s all the straps I used too! Fuuuuuudge.
    I didn’t have a mat, and alls that happened was it got scratched up. Loads of firewood. HEAVY f’ing rounds of Euc being thrown in. Never broke.
    I hope this little ‘ol mill can handle 4130!
  20. Feb 15, 2023 at 11:49 AM
    #80
    Topanga Taco
    Rick
    Let’s try this again, lol!
    yeah, you folks have me reminiscing alright! (Yeah yeah yeah, ;0)
    I used to use the Taco to skid too. It’s a video, but I took screen shots. The Taco’s size makes it easier to maneuver in tight spaces.
