Will the engine temperature display cool if the water pump is shot?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hot Plate, May 5, 2013.
  1. May 5, 2013 at 1:00 PM
    Hot Plate
    Hot Plate [OP] New Member
    1999 Tacoma 4x4 2.7
    Hi All,
    I have a 1999 Tacoma 4x4 with a manual transmission and a 2.7 engine.
    I'm getting the tell-tale loud screeching sound at start-up -- as well as a high idle speed and a low running temperature.
    Absent the screeching sound, I would assume the problem is simply the thermostat.
    But with the screeching sound present, I'm thinking the problem is likely with the water pump.
    However, if the screeching sound is being caused by a water pump problem, shouldn't the engine run hot, as opposed to cold?
    Thank you so much,
    HP
  2. May 5, 2013 at 1:07 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    sometimes it's just a blet but if you're over 100k I would be looking at replacing that pump anyways.
  3. May 5, 2013 at 1:09 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    If it screeches, it could be the bearings in the water pump that is bad. Temperature shouldn't play a role.
  4. May 7, 2013 at 1:10 PM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    I can't think of anything that would cause a low runnning temperature except a 'stuck open' thermostat.
    Maybe a piece of the water pump broke and jammed in the thermostat, or something else got into your coolant and hurt the water pump and jammed the thermostat.
    High idle might be caused by the low running temp.
  5. May 7, 2013 at 6:00 PM
    BamaToy1997
    Bill
    Navarre, FL
    A bad bearing in the water pump will make noise, and can cause possible leaking at the shaft, but as long as it spins, the pump will still flow water.
  6. May 8, 2013 at 1:44 AM
    Hot Plate
    1999 Tacoma 4x4 2.7
    Thank you for all the replies and suggestions.
    I replaced the thermostat and everything is fine now. Even the screeching went away, though I suspect it will come back.
    But I have to ponder whether the cold water flowing through the system could have somehow contributed to the start-up screeching.
  7. May 8, 2013 at 6:03 AM
    BamaToy1997
    Bill
    Navarre, FL
    If the noise went away, then I would be more inclined to believe that you had an issue with belt tension, which was eliminated when you did the repair.
  8. May 8, 2013 at 5:35 PM
    ppham444
    Phuong
    Portland, OR
    I still think the screeching will come back. Keep us posted.
