Will the spare tire mount hold a 33” spare?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco_Rob, Apr 25, 2018.
  1. Apr 25, 2018 at 10:37 PM
    Taco_Rob
    Taco_Rob [OP] Member
    Robert
    2010 Taco Sport 4x4
    GT3" Old Man Emu Susp Lift. 33" tires on 16" wheel. Fab Four front bumper with SmittyBilt 10k winch, warrior rear bumper.
    Whats up Taco Heads?! I know I’ve read somewhere about mounting a 33” spare tire in the factory mount with some small fab work.
    Has anyone dealt with this or have any info?
  2. Apr 25, 2018 at 10:45 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    MemphisTaco08 likes this.
  3. Apr 26, 2018 at 5:05 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    Take a BFH an whack the tabs that poke down or you could remove them an will fit. I bashed mine an was able to fit 255/75/17 no issue.
  4. Apr 26, 2018 at 5:32 AM
    mtmudrunner
    mtmudrunner Well-Known Member
    Wes
    Tomcreek corner, MT
    1985 Toyota 4x4 p/u
    Rust
    I have a 255/85/16 under mine granted its used but no problems so far,
  5. Apr 26, 2018 at 6:38 AM
    BeachBoy
    BeachBoy Well-Known Member
    VT & QC
    '09 DC LB Sport+Leather
    Icon Extended COs / Camburg UCA / ATX Predator Teflon / Mickey Thompson MTZ / Color-Matched emblems / All-Pro Bumper & skids / Stubbs HD-SKO / Alcans custom leafs / U-Bolt flip / Icon rear resi shocks / Rear Bumper
    I also have a 33" (used) Baja MTZ on 17" steel rim and it fits fine.
  6. Apr 26, 2018 at 7:39 AM
    youcantseeme
    youcantseeme Well-Known Member
    E
    Colorado
    2015 SSM Taco TRD
    13 cupholders for beer. All the Weathertechs.
    285/70/17 fits with zero trimming.
    MattCowsmasher likes this.
  7. Apr 26, 2018 at 7:43 AM
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    285/70r17 Falken here fits fine.
  8. Apr 26, 2018 at 7:50 AM
    Mile0tacoma
    Mile0tacoma Well-Known Member
    Hank
    Mile zero Alaska Highway
    2019 & 2018 Tacoma
    Mine has level kit, 34" tires, wife's truck is all stock
    I have 285/75/16 duratrac tire and it DOES NOT sit to my liking with the drivers side resting tight against the spring hanger and it sits right tight to the hitch tube in order to clear the diff. I just dont like how it contacts surfaces. I left it clamped up for a couple hours and removed it to see the indentations it was making and just not satisfied with it.
    microsnook likes this.
  9. Apr 26, 2018 at 7:50 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    255/85/16 Dick Cepek Extreme Country that fit fine.
  10. Apr 26, 2018 at 7:53 AM
    Extra Hard Taco
    R.J.
    Devil's Island
    You have a 3rd Gen though and we are referencing 2nd Gens. I'm not sure if the spare tire area is the same with dimensions and so forth between the two models.
  11. Apr 26, 2018 at 9:47 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Interesting that y’all didn’t have any problems.
    I had to remove the spare tire tabs off mine for it to fit, and now it hits the rear diff when flexing.
    OP, don’t cut the tabs off. Only bend if needed.
  12. Apr 26, 2018 at 9:50 AM
    crazy joker
    crazy joker Well-Known Member
    Jesse
    Charlotte area, NC
    2014 DCLB sport 4x4
    Real men just call it camping
    I had to move the spare tire hanger back about an inch to clear the diff. Otherwise it fit fine (255/ 80/ r17 Cooper ST MAX).
  13. Apr 26, 2018 at 9:54 AM
    reg0928
    reg0928 Well-Known Member
    Ross
    Crestone, Colorado
    05 TRD OR Access Cab
    3"OME, 255/85R16
    I've got a 305/75/r16 on mine with no problems
    Ceddingermtb likes this.
  14. Apr 26, 2018 at 9:58 AM
    s1t808
    s1t808 Sitting in the timeout corner
    HI > OCONUS
    2015 Taco
    Lift? Yea I got one of those
    Any mods required to fit the 305s? I hacked off the tabs in anticipation of needing to do it any case.
  15. Apr 26, 2018 at 10:02 AM
    reg0928
    Ross
    Crestone, Colorado
    3"OME, 255/85R16
    i didnt mod anything, but it sits against the tabs a bit. they could probably use a couple whacks with a hammer
  16. Apr 26, 2018 at 10:19 AM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    I have a 285 75 16 (new) and it fits fine. I moved the hoist 1” to the rear just to make sure when raised it is as far the the rear as possible without have to hold it back and crank at the same time. There’s a large hole that would limit drilling and bolting it inplace so I made 2 aluminum plates to sandwich the existing mount. Sorry a little confusing to describe. No pictures on phone anymore but can find one if it helps. I know I’ve posted on this subject before and I had attached photos.
  17. Apr 29, 2018 at 6:35 PM
    iJDub
    iJDub Well-Known Member
    What if I have the All Pro rear bumper with hitch? Can I still fit a 33" I was thinking about airing it down since I have an inflator...maybe that'll help.
  18. Apr 29, 2018 at 8:07 PM
    Pigpen
    Dan
    Northwest Montana
    I've read the AP hitch interferes with your spare tire.
    For anyone with the stock hitch putting a 33 in there... DO NOT cut off the tabs. Also be careful not to bend them too far. The tabs are what keep the tire from getting wedged above the rear diff when you flex the suspension. The tabs are easy to bend, but difficult to bend back once bent too far. My 33.5" 255/85/16 fits fine in there.
  19. Feb 1, 2021 at 3:43 PM
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    I would love to be able to fit a 295/70/17 yokohama G003 MT... I have 265/70/17 duratracs now.... looking to go to this for tires this summer, trying to get all setup, but i it wont fit, I'll be getting the Victory 4x4 rear bumper with tire carrier...
