will the v6 tacoma flares fit a 4 cyl?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by madden, Apr 14, 2011.
  1. Apr 14, 2011 at 6:12 PM
    madden
    madden [OP] Member
    I was planning on buying some tacoma flares to put on my 4 cyl tacoma, but will they fit?
    I know I will have to do extra work by drilling holes, but just wanted to know if the body lines would line up
  2. Apr 14, 2011 at 6:21 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    Body lines should line up fine. The clips used for securing the fenders are kinda squared shaped and so are the holes. It would probably be best to try and make the holes square if possible instead of just drilling them.
  3. Apr 14, 2011 at 6:23 PM
    jking3002
    jking3002 Well-Known Member
    Jonathan
    Kentucky
    Scion tC
    Ricer muffler, window tent, trd shift knob.
    I don't see why they wouldn't... Take for example an access cab. It can have either engine, but obviously the body of the truck, and thus the flares would be the same size.
  4. Apr 14, 2011 at 6:34 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Yes, the holes for the stock fender flares would be hard to duplicate and line up to get the stock clips to work right IMO, since the holes were probably stamp during manufacturing. I would look into aftermarket flares, you will probably be happier and it will be alot easier to install.
  5. Apr 14, 2011 at 6:38 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    I'm assuming that you actually mean will flares from a prerunner/4x4 fit a base model? Engine has nothing to do with flares
  6. Apr 14, 2011 at 6:50 PM
    HomeGrown
    HomeGrown Well-Known Member
    Bill
    South Bend, IN
    2014 Reg Cab 4WD
  7. Apr 14, 2011 at 6:57 PM
    Kingfrog
    Kingfrog Well-Known Member
    08 TRD Rugged Trail Edition
    Undercover,Pop n Lock, Hardwired GPS, Garage door opener , Scanguage II, wireless back up camera, X994 Basslink, ...Prefer stock and non invasive functional mods
    Like them even more than my plain sock plain ones. The recessed attachment holes make the truck look a lot more rugged and less like a "Limited" edition.......Very Nice.(not sure about the chrome Westin Bull bar though..Black would have been my choice for that thing. Plasticoat it! (maybe the skid plate part only) I like brawny looking street trucks whether "mall crawlers" like mine or slightly modded off roaders.
  8. Apr 14, 2011 at 7:05 PM
    beachbumberry
    beachbumberry Well-Known Member
    andrew
    fl now, tx native
    05 sr5 4x4 access cab
    leveling kit, american racing rims, push bar, nerf bars
    i have factory flares on mine and the last owner replaced the fender on one side (one can only assume after a fender bender) with a standard fender... couldn't tell the difference until i got to highway speeds (for the first time 6 months after i bought it, speed limit is 45 all through north florida). when i hit that magic 70 mph i heard a bang like the tire popped, pulled over and the flare had folded back on itself. if you do go the factory flare route, i suggest doing what i did and pop a few rivits along the bottom edge, otherwise you will be running the same risk. i've done much more 70mph blasts since then, no problems
