will these 2009 stock wheels fit on my 98 tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by G-reg, Jul 8, 2010.
  1. Jul 8, 2010 at 12:23 AM
    G-reg
    G-reg [OP] Member
    Western Washington
    98 Tacoma 4 cyl
    I have a 1998 Tacoma 4x4 and was wondering if the stock wheels from the 2009 tacoma will fit onto it. they look like they will but i havent taken any measurements. Thanks
  2. Jul 8, 2010 at 12:35 AM
    RPain
    RPain I drink, and I know things
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    If your 98 is a 6-lug yes but if its a 5-lug no
  3. Jul 8, 2010 at 12:46 AM
    G-reg
    G-reg [OP] Member
    Western Washington
    98 Tacoma 4 cyl
    yea its a 6 lug i didnt even know they made 5 lug.
  4. Jul 8, 2010 at 1:13 AM
    RPain
    Chandler, Arizona
    most 4 cyl 2wd's are 5 lugs haha
  5. Jul 8, 2010 at 9:19 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    The bolt patterns will match up no problem but I think the 2nd gen stock alloy wheels are all +30 mm of offset whereas the 1st gen stock alloy wheels are +15 mm of offset. The difference is about 9/16ths of an inch.
    2nd gen wheels mounted on a 1st gen truck will be tucked in 9/16" further into the wheel well. Depending on the tire mounted on the wheel, you could see some rub in front on the upper control arm. I don't think there are any interference issues on the brake calipers.
    There are several TW members who are running 2nd gen wheels on their 1st gen Tacomas.
  6. Jul 8, 2010 at 10:26 AM
    G-reg
    G-reg [OP] Member
    Western Washington
    98 Tacoma 4 cyl
    hmm ok. I have 30" bighorn maxxis tires I was going to run with them. They seem pretty narrow but is there a way i can tell if ill have rub?
  7. Jul 8, 2010 at 10:34 AM
    Digiratus
    Roaming the PNW
    The RedHead
    What is the actual size of the tire? 245/70-16?
