Will these fit? 285/75/16
Discussion in 'Wheels & Tires' started by Matic, Aug 21, 2010.
  1. Aug 21, 2010 at 1:15 PM
    Matic
    Matic [OP] Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    2002 TRD prerunner,SR5, doublecab
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    Duratracs? All the tire shops I spoke with today says that they rub on the UCA.
    I have OME 881 coils up front with what looks to be a .5 spacer.
  2. Aug 21, 2010 at 1:17 PM
    Matic
    Rich
    Greenville,sc
    And can I put a 1in top plate on to give me a solid 3"? I have the pro comp AAL and pro comp shocks in the rear and i'm still getting a little bit of rake towards the front.
    I dont want to mess up my steering geometry but I keep hearing you can go a full 3" in the front.
  3. Aug 21, 2010 at 1:19 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    Don't stack lifts. I think you will rub with the lift you have.
  4. Aug 21, 2010 at 1:29 PM
    Matic
    Rich
    Greenville,sc
    What do you mean "Dont stack"?
    I was gonna lose the .5 top plate and put the 1" in.
    I looked and there seemed to be 2" between the top of the tire and the UCA.
    Granted...the side wall bulges on the inside of the tire but thats aprox 2" down from the top of the tire.
    If i'm correct, the 285/75 should give me only an inch of lift.
  5. Aug 21, 2010 at 1:37 PM
    Matic
    Rich
    Greenville,sc
    I guess what I'm asking is, is anyone running these tires on a 1st gen with a 2.5 or 3" lift?
  6. Aug 21, 2010 at 1:38 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    Thought you were planning on putting another spacer on top of what you already had. If you have 2-3" of lift you should be fine, you just might have to do a little trimming.
  7. Aug 21, 2010 at 1:40 PM
    Matic
    Rich
    Greenville,sc
    Yea. I dont mind trimming plastic. It's just that the 3 shops that I called for tires said they are going to rub on the UCA.
  8. Aug 21, 2010 at 1:43 PM
    bivey
    bivey Well-Known Member
    They will rub at certain angles.
  9. Aug 21, 2010 at 3:24 PM
    Matic
    Rich
    Greenville,sc
    Anyone else? Thoughts?
  10. Aug 28, 2010 at 10:10 PM
    Matic
    Rich
    Greenville,sc
  11. Aug 28, 2010 at 10:11 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Are you running after market wheel? You'll rub on your UCA with stock wheels
    I don't recommend wheel spacers
    4.5 Back spacing is ideal
  12. Aug 29, 2010 at 6:33 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    x2 this is going to depend entirely on your wheels now.
  13. Aug 29, 2010 at 6:42 AM
    Matic
    Rich
    Greenville,sc
    Not sure of the backspacing on my current wheels which are MB V drive 16".
    I would like to go with the pro comp series 52 or 98. So with the 4.5 backspacing on these rims, is my tire going to stick way the hell out? Not a big fan of that look.
