Will these fit my truck
Discussion in 'Wheels & Tires' started by Newcomer24, Dec 1, 2012.
  1. Dec 1, 2012 at 8:25 AM
    Newcomer24
    Newcomer24 [OP] Member
    05 PreRunner SR5
  2. Dec 1, 2012 at 8:29 AM
    Large
    Large Red
    I'd say 265/70 but you might rub the UCA. Might want to stick with 265/65
  3. Dec 1, 2012 at 8:29 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Holy 31 lb weight per wheel. That's heavier than 16" steel wheels.
  4. Dec 1, 2012 at 8:35 AM
    KenLyns
    Belly of the Beast
    It won't rub on the LCA, because the XDs are more outset than stock. 0.5" wider but pushed out 0.8". However, 265/70 may rub on the mudflap as a result of the outset. A number of choices:
    - Get 265/65 (TRD Sport stock size).
    - Get 265/70 and run no flaps.
    - Get 265/70 and get Huskyliner flaps, which have more clearance.
  5. Dec 1, 2012 at 3:42 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Great recommendation. Also keep in mind that if in the future you plan to add a lift and want to go with wider tires, you will end up rubbing the uca with this BS.
