Will these fit without a lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Thatcarter85, Feb 15, 2023.
  1. Feb 15, 2023 at 4:36 PM
    Thatcarter85
    Thatcarter85 [OP] Member
    Daniel
    2018 toyota tacoma TRD 4×4
    I purchased 20×10 black wheel moto metal MO962 6×5.5 -24 Rims
    I bought LT285/55R20 Venom Power Terrain Hunter X/T Hybrid AT/MT tires.
    Can I get these to fit without extended studs and a lift kit??
  2. Feb 15, 2023 at 4:38 PM
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    A 32.5" diameter tire with -24 offset will likely create some rubbing with the wheel turned.
    Thatcarter85[OP] likes this.
  3. Feb 15, 2023 at 4:39 PM
    Thatcarter85
    Daniel
    How do I fix that issue without a lift kit? I have a 2in leveling spacer kit I'm installing tomorrow. A guy at the tire shop said my studs needed extended as well. Do I need wheel spacers to do that?
  4. Feb 15, 2023 at 4:41 PM
    dangeroso
    Jon
    Dallas, TX
    -24 offset is already pushing your wheels out a lot. I don't think spacers are going to help you any, honestly. You are probably looking at a lift, a cab mount chop and maybe some pinch weld hammering.
    What did the tech mean by the studs need extending? Maybe that you need extended thread lugs?
  5. Feb 15, 2023 at 4:51 PM
    Thatcarter85
    Daniel
    They said the lug nut did not have enough thread screwed on to hold the tire properly. So they suggested extended studs to get enough thread for the lug nuts to hold
  6. Feb 15, 2023 at 5:00 PM
    dangeroso
    Jon
    Dallas, TX
    Extended thread lugs is a more common solution than replacement of the studs. That’s typically done when you add really thick spacers, like in racing wheel configurations.
  7. Feb 15, 2023 at 5:12 PM
    Yotalicious
    Yotalicious Member
    MA
    2023 Tacoma OR DCSB
    20 inch wheels...:pout:Another bro truck on the road.
    TacoGranny, Vmax540 and Chew like this.
  8. Feb 15, 2023 at 5:12 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    You're gonna have to trim a ton....
    My 17x9 -12 offset wheels (285/70/17 tires) still rub after lifting (2.5") and trimming some plastic + CMC.
  9. Feb 15, 2023 at 5:15 PM
    dangeroso
    Jon
    Dallas, TX
    That's my setup, almost. I'm at -10, 285/70/17, 2.5" lift and CMC, and I am completely clear, even at full wheel lock. I did hammer the pinch weld down though and cut out a lot of plastic that was covering it up.
    Where are you still rubbing?
  10. Feb 15, 2023 at 5:53 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Lift does not help clear larger tires, unless you are planning to drive in a straight line and never cycle your suspension.
    With that offset and size, you will have a lot of rubbing.
    TacoGranny and dangeroso like this.
  11. Feb 16, 2023 at 2:46 AM
    Thatcarter85
    Daniel
    It rubs slightly on the side fender wall on the inside when turning the wheel. Plenty of clearance in height and behind the tire
  12. Feb 16, 2023 at 2:58 AM
    Thatcarter85
    Daniel
    Where did trim the plastic
