will these fit?
Discussion in 'Wheels & Tires' started by Rhino, May 23, 2011.
  1. May 23, 2011 at 11:11 PM
    Rhino
    Rhino [OP] Well-Known Member
    Laurel, Mississippi
    03 TRD SR5 4x4
    gray wire mod, blacked out, debadged, toolbox foglights, cb in dash, system, bilstein 5100's in front wrapped in eibach coils, 5125's in the rear with 2 inch aal and 1 inch shackle, diff drop kit, extended rear brake line, 8000 lb smittybuilt winch on a custom winch bumper, 2 4 inch 100 watt kc's and 2 6 inch 100 watt kc's on the bumper, sometimes a ladder rack,much more to come
    these are the cooper discoverer s/t maxx if i get 265/75/16 will they fit on my 03 with stock wheels and tires with no lift? and if they will fit would it require any trimming?
  2. May 23, 2011 at 11:14 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Yes they will with a 1-2 inch lift, and either 4.5 bs wheels or add some spidertrax wheel spacers otherwise they will rub your drivers side frame
  3. May 23, 2011 at 11:21 PM
    Rhino
    Laurel, Mississippi
    03 TRD SR5 4x4
    so they wont fit if i leave it all stock huh?
  4. May 23, 2011 at 11:25 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    If you have stock wheels they will definitely rub the frame on the driver side..
    mine did until I put wheel spacers on and it solved it.. but the tire looks to be slightly under the frame at full lock so I believe if I wasn't lifted, you just need 2 inches, i just have some ome springs and shocks, I think you would still rub the frame.. you can still drive it its just annoying
    because it reduces your turn radius.
  5. May 23, 2011 at 11:30 PM
    Rhino
    Laurel, Mississippi
    03 TRD SR5 4x4
    ok thanks for the help man now i just gotta decide if i wanna lift it or go one size smaller tire
    oh and do you know what size wheel spacer i'd need?
  6. May 23, 2011 at 11:55 PM
    ratrod
    ratrod Well-Known Member
    Los Angeles
    2006 Toyota Tacoma Dbl Cab TRD SR5 4x4
    Bilstein 5100s @ 1.75 with 1.5 AAL, Satoshi Grill Mod with 2 Hella 500s behind the grill, LED dome and map lights, custom made (by me) 10" subwoofer box behind the dbl cab seat, DVD/iPod/Bluetooth/GPS/TV/USB/Stereo, Yakima rack, Shell, tinted front windows to match the factory backs. Backup cam in the tailgate handle mod.
    Thanks for the picture of the tire, havent looked at cooper tires as an option for new ones, I think I might buy those!
  7. May 24, 2011 at 12:58 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Whatever you want
