Will these fit?
Discussion in 'Wheels & Tires' started by Superdavert, Jun 27, 2011.
  1. Jun 27, 2011 at 7:22 AM
    Superdavert
    Superdavert [OP] Well-Known Member
    Dave
    Athens, Ga
    '09 TRD Sport DC SB
    20" Enkei Deep 6 wheels wrapped in 275/60 20 Hankook Dynapro ATm, ProComp 2" leveling kit, Foglight anytime mod, Sockmonkey TRD Sport bedside decals, Extang Trifecta tonneau cover, Toyota bed extender, Aries black nerf bars, Pop & Lock 8521 Powered tailgate lock
    I found some 20" Enkei deep 6 XSP wheels for sale that were off a Tundra. I tried to find specs and all I found is that they are 20x9.5 and and maybe a offset of 8. They also come with 285/50 20 nitto Terra Grapplers. Its a 31.22" in tire. Will I get much rubbing with a 2" lift?
  2. Jun 27, 2011 at 7:24 AM
    Matic
    Matic Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    2002 TRD prerunner,SR5, doublecab
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    285/ should be a 33. Yes. you will rub, major on a 20.
    Anyone?
    I'm 16x8 1/2 on 33 and rub forward left/ reverse left. The offset is not 8. Look at the inside of the rim.Or measure the BS.
  3. Jun 27, 2011 at 7:40 AM
    Superdavert
    Dave
    Athens, Ga
    '09 TRD Sport DC SB
    I got the tire diameter on this site's tire calculator. I've googled to find the specs for the rims, but I must be doing it wrong b/c I can't find much. The wheels for sale are from an individual that's 4 hours away so I can't measure. I'm also pretty sure that 285's come in more than a 33.
  4. Jun 27, 2011 at 9:58 AM
    Superdavert
    Dave
    Athens, Ga
    '09 TRD Sport DC SB
  5. Jun 27, 2011 at 10:03 AM
    Sport11
    Sport11 Well-Known Member
    Kingsport, TN
    Dodge Ram 1500
    285 is the width of the tire, not the overall diameter.
  6. Jun 27, 2011 at 10:13 AM
    Sport11
    Kingsport, TN
    Dodge Ram 1500
  7. Jun 27, 2011 at 11:10 AM
    Superdavert
    Dave
    Athens, Ga
    '09 TRD Sport DC SB
    So I looked at that chart using the offset I can find on the web (8). It falls between a backspace of 5.5 and 5.75. Would that be too much BS on the Tacoma to run a 285 with only a 2" lift.
  8. Jun 27, 2011 at 11:38 AM
    Sport11
    Kingsport, TN
    Dodge Ram 1500
    I would say that it will not fit. For a 285, you need 4.5" backspacing. Where is KPT? He would be able to tell you for sure!!!
  9. Jun 27, 2011 at 12:37 PM
    Superdavert
    Dave
    Athens, Ga
    '09 TRD Sport DC SB
    KPT definately will know. I've seen tacos with these wheels on them. So I don't know what tires or even spacers they use. I saw one with 295's with now lift on this site. I don't know how he doesn't rub with that width.
  10. Jun 27, 2011 at 1:18 PM
    Sport11
    Kingsport, TN
    Dodge Ram 1500
    You could probably fit the 285's on there but I would think there would be some major rubbing with 5.5 - 5.75" of backspacing. Spidertraxx wheel spacers are 1.25", so that would get you out to the 4.5" of backspacing needed. A lot of guys on here run them, but I don't have any experience with them personally.
  11. Jun 27, 2011 at 2:41 PM
    Superdavert
    Dave
    Athens, Ga
    '09 TRD Sport DC SB
    Thanks Matt for your help.
