will these fit
Discussion in '1st Gen. Tacomas (1995-2004)' started by fireturk41, Jan 29, 2009.
  1. Jan 29, 2009 at 4:54 PM
    fireturk41
    fireturk41 [OP] I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    hi will a 265/75/16 fit a stock tacoma 4x4? theyre Destination M/Ts im trading them to a friend for my street tires (i got for free michelins though)
    also what could be wrong with my laptop i cant open TCWorld on it it comes up as the page has an error or something
  2. Jan 29, 2009 at 4:55 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep....those tires should be fine......may have a tad bit of rubbing, but nothing serious. and for the laptop....try erasing any junk/cookies and stuff and see if that works.
  3. Jan 29, 2009 at 5:04 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    thanks and will a lift help with rubbing cause i need an excuse for one
  4. Jan 29, 2009 at 5:31 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    to a point maybe,but wheel spacers are all ya really need if there is any rubbing. i doubt you'll have barely any rubbing tho. but if you do get wheel spacers...................go with spidertrax.
  5. Jan 29, 2009 at 9:37 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    265 75 16 isnt going to cause a ton of rubbing for normal every day driving...you MAY have to remove your mud flaps and you MAY have to pound down the pinch weld/trim the fender liner at that point...and you MAY get some rubbing on the frame at full lock
    but you should be ok for the most part with that size tire
    if not then just get you a mild lift (like 2") and youre all set
  6. Jan 29, 2009 at 11:55 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    your all wrong. haha I have 265 75 16 bfg at's and i did about 12 separate hours of pounding on the pinch weld and inner fender to make em fit. (still rub on occasion)also had to get spacers cause they were rubbing the frame. they will fit, but your gona have to make them fit.
  7. Jan 30, 2009 at 12:22 AM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    Sacramento
    2008 TRD Off-Road
    Little this. Little that
    idk what ^^^^ that is all about
    my 02 prerunner was running 265/75R16 no problem. i went through a whole set of tires without any rubbing..
    hmm... wierd
    they will deff fit
  8. Jan 30, 2009 at 12:36 AM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    idk what ^^^ is talking about, but NO WAY! oh wait it's a prerunner. i'll re phrase that,
    If you drive your truck like a truck it;s gona rub, it you drive it to and from work and the beauty salon, your fine!
  9. Jan 30, 2009 at 12:44 AM
    t.hornstra
    Ted
    Sacramento
    2008 TRD Off-Road
    so u think driving a truck like a truck is only offroad or on rigorous trails?
    i believe they made pickup trucks so you could haul stuff back and forth and not have to worry about getting your trunk or car dirty.. go buy a dunebuggy or rockcrawler
    i use my truck to haul stuff to/from college. trips to the beach, camping, snowboarding. and whatever else i feel like.
    im telling you i bought my truck with 265/75R16 on the stamp steel wheels. they never rubbed for me.
  10. Jan 30, 2009 at 12:47 AM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    no im just trying to bring some excitement to tw. but you are saying you don't stuff the tires up tight into the wheel well. so therefore my post is correct. they fit for everyday driving(mine still needed some pounding to fit for every day driving) but if your gona wheel it hard at all, i'd get the lift asap and don't waste time pounding.
  11. Jan 30, 2009 at 12:51 AM
    t.hornstra
    Ted
    Sacramento
    2008 TRD Off-Road
    hmmm wierd. whats the BS on ur wheels?
    i havnt pounded anything or removed anything in my wheel wels
    ive been on some trails and flexed my truck.. maybe not enough to notice any rubbing.
  12. Jan 30, 2009 at 12:53 AM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    go look at your pinch weld, I bet it's already been done if the previous owner installed them. check it out anyways!
  13. Jan 30, 2009 at 12:59 AM
    t.hornstra
    Ted
    Sacramento
    2008 TRD Off-Road
    idk i didnt notice anything when i was installing my lift. : /
    maybe it was done really nicely.. haha
  14. Jan 30, 2009 at 1:00 AM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    well the actual weld is behind plastic so it could have been.
  15. Jan 30, 2009 at 6:50 AM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    i put 265/75/16s on my truck long before i lifted it and had only rubbing on the frame at full lock and that was offroad
    and trust me...i put my truck thru its paces offroad
    you'll be fine with that size without a lift and MAYBE a little pounding/trimming
  16. Jan 30, 2009 at 3:00 PM
    t.hornstra
    Ted
    Sacramento
    2008 TRD Off-Road
    ^^ Thanks for backin me up! haha
    i could have sworn my truck had no mods and it was running them no problem.
    you WILL be able to run 265/75/16s NO major if any small Problems : ]
  17. Jan 30, 2009 at 3:05 PM
    t.hornstra
    Ted
    Sacramento
    2008 TRD Off-Road
    it also depends on what tire brand/model i think.
    some tires have tread that sticks out further over the edge. mine are Toyo AT. and they didnt rub. maybe BFG have more tread that reaches the frame at full lock. :drevil:
    anyone else agree?
  18. Jan 30, 2009 at 3:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I ran 265/75/16's on my 2000 4x4, and never rubbed. Just the slightest bit full locked, and with the tire stuffed. Perhaps your trucks suspension was worn out?
  19. Jan 30, 2009 at 6:45 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i agree......see my first post on the thread!;)
