Will these fit?
Discussion in 'Wheels & Tires' started by btdawgs10, Dec 17, 2014.
  1. Dec 17, 2014 at 4:04 PM
    btdawgs10
    btdawgs10 [OP] Well-Known Member
    Alabama
    08 PreRunner SR5 2wd
    I have a 2008 access cab 2wd with Bilstein 5100s set at 2.5 with stock 3 leaf rear. I was wondering if I can fit 285/75/r16 with this setup.
  2. Dec 17, 2014 at 4:05 PM
    AndyTaco
    AndyTaco ACLBFTMW
    Andy
    Waco, TX
    '10 ACLB V6
    "Raptor Style" grill mod, aftermarket wheels, 265/75/16 Goodyear Wrangler Authorities, TRD Shoulder pads on seat belts, no mud flaps, AVS Hoodflector bug shield *removed*, Dee Zee Ultrablack Bull Bar w/ license plate mount, dipped my fuel door for no reason, N-Fab Spare tire mount w/ full size matching spare, dipped eyelids onto my headlights for no reason, dipped my hood for no reason
    Might experience some rubbing, but nothing a little trimming can't fix. 265's would fit better, that's what I have.
  3. Dec 17, 2014 at 4:58 PM
    gdog
    gdog Well-Known Member
    NOVA
    2022 TRD Off-Road
    Wheels, lift, more as I discover them....
    Lotta sidewall there sir!
    G
  4. Dec 18, 2014 at 10:28 AM
    btdawgs10
    Alabama
    So it would just be some minor trimming in the front the back would be fine correct
  5. Dec 18, 2014 at 10:30 AM
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Stock wheels or aftermarket?
  6. Dec 19, 2014 at 2:38 PM
    btdawgs10
    Alabama
    Stock wheels
  7. Dec 19, 2014 at 2:57 PM
    btdawgs10
    Alabama
    What if I went with 275/70r16 would I have any rubbing issues then
  8. Dec 21, 2014 at 7:09 PM
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    You'll need wheel spacers w/ 285's. Can't speak for the 275's from experience
  9. Dec 21, 2014 at 7:15 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    You have 5100's @ 2.5 up front and a completely stock 3 leaf rear?
  10. Dec 22, 2014 at 10:12 AM
    btdawgs10
    Alabama
    Yes that is correct 2.5 and stock 3 leaf rear
  11. Dec 22, 2014 at 6:11 PM
    btdawgs10
    Alabama
    what about getting 255/80r16 will these fit with no rubbing issue I used the tire size calculator and it said it is a 32 inch tire 10 inches wide
  12. Dec 22, 2014 at 6:49 PM
    AndyTaco
    AndyTaco ACLBFTMW
    Andy
    Waco, TX
    '10 ACLB V6
    That's still a lot of circumference... Don't know if it will fit. It's just less wide.
    EDIT: Forgot you have a lift. I think it will fit.
  13. Dec 23, 2014 at 4:54 AM
    btdawgs10
    Alabama
    A 265/75r16 tire which will fit on stock suspension is 31.65 inches and a 255/80r16 is 32.06 inches and a little skinnier so I think they will fit maybe minor rubbing at full lock unless I'm looking at this wrong. Any opinions??
