Will these help with tire rub?
Discussion in '1st Gen. Tacomas (1995-2004)' started by pugdaddy2576, Dec 23, 2011.
  1. Dec 23, 2011 at 12:08 PM
    pugdaddy2576
    pugdaddy2576 [OP] Active Member
    Brad
    Central Ky
    02 Tacoma SR5 TRD
    Grey wire mode, deck plate mod, 3" lift
    I have a 2002 Tacoma with a 3 inch lift. 5150 Bilstein shocks with a half inch spacer up front and 1 and half in aal in the rear. Im running 31 x 10.50 on 15 inch rims. I also have an inch and a quarter wheel spacers behind the rims. My question is will buying a set of Total Chaos or ICON UCAs help get rid of tire rub. I only have rub when I make hard turns. Im also thinking of upgrading those 31s to 33s. Thanks for the help guys.
  2. Dec 23, 2011 at 12:53 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    The UCA will only allow 1" more of travel.
    Are you rubbing on the frame? <-- Meh
    Are you rubbing on the firewall? <--- Pinchweld mod..
    Wheel backspacing and spacers are the only thing that can help with tire rub, and the obvious, cutting/hammering the fenderwells in.
  3. Dec 23, 2011 at 5:00 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    How the hell are you rubbing on 31x10.5s?? I ran those on stock rims with no problem..
    Wheel spacers are all you can really do.
    Do the pinch weld mod
  4. Dec 23, 2011 at 5:14 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    where are you rubbin? when i had a 3 inch lift i had 33s on my 02
