Will these Pacer wheels fit?
Discussion in 'Wheels & Tires' started by RCOTaco, Apr 30, 2012.
  1. Apr 30, 2012 at 7:29 PM
    RCOTaco
    RCOTaco [OP] Long Time Lurker
    Dalton
    Hamlet, NC
    Super White DCSB 4x4
    Bilstein 5100s on Stock Coils, Light Racing UCA's, Pro Comp Wheels, 265/75 Baja MTZ's, Cobra 18 WXST, 4' Firestik, UWS Toolbox
    Originally, I wanted the Mickey Thompson Classic II's, but since they won't fit, I am trying to find an alternative.
    My search came up with these.
    http://www.customwheelsexpress.com/custom-wheel-manufacturer.php?cm=164B-6883
    My question is, does anyone know if these wheels will work on the 2nd gen.?
    Also, Pacer is a "cheap" wheel, meaning it isn't a name brand, so how do y'all think these will hold up, finish wise?
    Thanks!
  2. Apr 30, 2012 at 7:46 PM
    mjm540ii
    mjm540ii Ding Dang Dee
    Oxford, PA
    2010 TRD Sport AC V6
    Fog light mod, interior LED's, illuminated switch, B110 5100's in the rear, Satoshi Grill, Hella 500's, 4X Innovations sliders, rear diff breather mod, painted rocker panels, bhlm, yellow wire mod, CB, Wheeler's 2"aal, Allpro diff skid, ubolt flip, LR UCA's, 885X's w/ 13mm spacer on 5100's, Spydertrax spacers, Relentless IFS/ mid/ T case skids, 255/85/16 KM2s, block heater, DTRL mod, T2 eyelids, Wheelers Superbumps, Extended SS brake lines, ATO shackle flip kit,1" 4Crawler BL, Elite fr plate bumper, Flyzeye LEDs, Drilled and slotted rotors, 20" LED bar
    Wheeler's steelies are MUCH cheaper... Just sayin
  3. May 1, 2012 at 2:38 PM
    RCOTaco
    Dalton
    Hamlet, NC
    But Wheeler's steelies are steel, these aren't.
  4. Nov 19, 2012 at 5:40 PM
    D.Holliday
    D.Holliday Well-Known Member
    Jon
    Portland, Oregon
    2008 Tacoma DCSB TRD Sport SR5 4x4
    Extang Trifecta Tri-Fold Tonneau Cover|Pioneer AVH-P1400DVD|3" Revtek Lift w/AAL|Pro Comp 7069|285x70r17 Federal Couragia MT's|Extra D-Rings Mod|Anzo Black Headlights|Corbra 75 CB w/3' Cobra Antenna & 4' Firestix Antenna|DTRL's Mod|L.A. Angels Sticker Mod|Smoked Aftermarket Tail lights
    RCOTaco, I know this is old but just wanted to give my 2cents for anyone looking at these. I just recently had these "put on" my 08 Tacoma TRD Sport in a 17x9 4.5 bs with -12 offset at a local Les Schwab in Oregon. I was pretty excited to see them UNTIL every problem imaginable started happening. First, the sensors for our wheels will not mate up with the hole in these wheels, so you'll need to buy 4 new sensors, which gets spendy. Second, I needed to buy new ET lugs just to get them to thread safely. Finally, they got the wheels on, it looked fantastic (this is with a 3" Revtek and 285/70/17 tire), they started to back it out of the shop and heard a loud grinding, pulled it back in and the calipers had cut a deep trench into the inside of the wheel. We decided to try a 1/4 spacer on the front, that ended up pushing the wheel out enough to fit, but now not even the ET lugs would screw down enough to saftly seat the wheel (leaving only two threads left and risking scratching up the outside of the wheel) so that was a no go. And so, where this was suppose to be a 1 hour process of putting on these wheels, it took roughly 6 hours at Les Schwab and I still drove home in the same truck I showed up with but with my TPMS going off. :(
    I know that my truck is a TRD Sport and like TRD Off-Roads, I believe I have bigger calipers then a baseline Tacoma (maybe i'm wrong, im just guessing) but if anyone who is reading this has concidered these wheels, I'd save yourself the trouble, even in a 17x9 wheel, they won't work.
    I am now looking at the Pro Comp 7069 17x9 (I may be the guinea pig for these as well, but what the hell). According to Pro Comp, they fit without a doubt, we'll see on Friday I guess.
  5. Nov 19, 2012 at 5:47 PM
    D.Holliday
    Jon
    Portland, Oregon
    Oh yea, by the way, Pacer will tell you they will 100% positively fit, but they won't. Not on a Sport anyways. ;)
  6. Nov 19, 2012 at 5:48 PM
    IronCladTRD
    IronCladTRD Consistently Irregular
    Corbin
    Hotel California
    2003 4x4 Manual V6 3.4L
    5100s/Eibach 3" lift, All-Pro Expo rear leafs, Elite front bumper & sliders, Smittybilt XRC8 winch, 33x10.5r15 BFG All terrains, Ultra Rogue 15x8 rims, homemade bed rack, Midland 1001z CB radio Deckplate mod, Century shell, train horn, debadged
    Dang it, I came to see you trying to fit AMC wheels on your Tacoma.
