Will these rims fit??? 96 tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by Aburton11, Feb 27, 2015.
  1. Feb 27, 2015 at 3:22 PM
    Aburton11
    Aburton11 [OP] Member
    Ohio
    96 4x4 Tacoma v6 3.4
    Will these rims fit on my 1996 4x4 tacoma KMC Wheels XD Series Hoss XD795 Gloss Black Wheel (16x8"/6x5.5")
  2. Feb 28, 2015 at 11:41 PM
    TimPall13
    TimPall13 Well-Known Member
    Tim
    Sandy Oregon
    3link SAS 02 SR5 Limited V6
    Lift: TrailGear 3link SAS with Fox 2.0 Coil overs in front. Custom Alcan Leafs with relocated Fox 2.0 shocks in rear. Sitting at 6in of lift. Armor: Relentless Fab Front bumper with home made hoops and Warn VR Evo 10s winch. Relentless Fab Rear bumper with swingout gate. Gears/Grip: 4.88 gears with ARB Air lockers front and rear. 35x12.5 Mickey Thimpson Baja Boss MTs on 17in Trail Ready Beadlock wheels. Lighting: 6000k 55w HID head lights in Retrofit Prejectors, KC Slim Light LEDs behind a Grillcraft grill and on CBI windshield mounts, And LED rock Lights. Performance: 6" deckplate mod, URD Crank Pulley, K&N air filter, ISR mod, and a AirRaid throttle body spacer, magnaflow muffler. Audio: Alpine speakers and sub running on a Alpine 5ch amp. All ran with Stinger wire kit, and a Alpine touch screen reciever. Extras: 15% Window Tint, Spray in bed liner, LineX coated factoey fender flares, Custom Roof rack/Track system, SoftTopper Canopy, Viair Dual 444c Onboard air with dual 2.5Gal tanks.
    Hey,
    Based on information you've givven they should work with no problem but.... Check on the rear offset and tire size you plan to run. Some wheel and tire combinations will make the tires rub on the upper control arms, inner fender, front bumper corner, or the frame. What tire size you plan on running?
    Tim
