Will these Rims Work
Discussion in 'Technical Chat' started by SamSter0077, Feb 17, 2009.
  1. Feb 17, 2009 at 5:22 AM
    SamSter0077
    SamSter0077 [OP] Happy Camper
    Katy, TX
    09 Tacoma 4x4 TRD OR
    OME 886 Coils, and Struts, Rear Toytec TSB AAL/ OME shock absorbers, Fog Lamp anytime mod, Voyager Brake Controller.
    I have a friend selling some Rims, [FONT=&quot]16x8 with 4.5" BS. I want to run 285/75-16 BFG All Terrains on a stock Prerunner. Will this work for me? I do NOT want to change the UCA's as they are pricey.. [/FONT][FONT=&quot][/FONT]
    My Friend has them currently on the older Style Taco 4x4.
  2. Feb 17, 2009 at 5:24 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    285's will not work with no lift. The wheels will fit though. just put 265's on them and yu'll be good to go
  3. Feb 17, 2009 at 5:28 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    what he said :thumbsup:
  4. Feb 17, 2009 at 5:31 AM
    SamSter0077
    Katy, TX
    What about 5100's on the front, and blocks on the back. Will the 285's work? I think I can fit the 265/75/16 BFG with the factory rim, I only want to buy the "used" rims if I can make the bigger tire fit. If I would require a 3" lift, that's ok.. 3" lift and cutting or new control arms.. NO.
    thanks!
  5. Feb 17, 2009 at 5:45 AM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    well it starts going into shades of grey. 3" lift and the wheels will allow your 285's to fit but there maybe a little rubbing on the mud flaps. So take off the mudflaps and do some minor trimming (Longbow has good pics of the trimming) and you got your set-up. The UCA's are not a must but I would recommend them with the lift. I went 25000 miles with stock control arms with everything being ok, the alignment wasnt perfect (wheels were like this \...../ slightly) and it wondered a little but it will work.
    Edit: oh fyi, If your hauling your camper trailer thats in your pic alot the lift and 285's will hurt your gas mileage but you'll look good doing it:D
  6. Feb 17, 2009 at 10:58 AM
    SamSter0077
    Katy, TX
    Hmm towing is job #1.. maybe I should stick with the stock rims, and 265/75-16... Until I can spend the money to do it right. Thanks!
  7. Feb 17, 2009 at 11:18 AM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    probably for the best, you dont want that wonder with a camper trailer behind you
