Will these spark plugs work for our trucks?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BUDSHAD, Aug 20, 2009.
  1. Aug 20, 2009 at 5:18 PM
    BUDSHAD
    BUDSHAD [OP] Smartass Killa
    Chad
    Macon, Ga.
    08 TRD 4X4 SR5
    Redline D6 tranny fluid. Redline gear oils in front and rear diffs. Bug shield and rain gaurds. Mossy Oak seat covers until I can afford the Wet Os.
    Denso part# PQ16TT and there is a 4507 under that first number on the end of the spark plug box. This is what the guy at AAP gave me when I asked for plugs for my truck. Any suggestions?
    PS
    I have the 4L. 6
  2. Aug 21, 2009 at 7:01 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    You want any of those numbers there in bold. I would recommend the standard ones (3381)
    http://www.globaldenso.com/en/products/aftermarket/plug/pnchart/chart_05.html
    PQ is a platinum plug but I don't see it listed here^^^. Denso doesn't list a platinum plug for the 1GR on their website.
  3. Aug 21, 2009 at 7:32 AM
    BUDSHAD
    Chad
    Macon, Ga.
    08 TRD 4X4 SR5
    Thanks Ben. Guess I will take these back and get the standard 3381. Wonder why his computer showed the plug he sold me? Oh well. Dont want to fuck my truck up with the wrong ones. Truck only has 9000 miles anyway.
    Thanks again
    Chad
  4. Aug 21, 2009 at 7:35 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    9000 miles? Why are you changing them? Is something wrong? I wouldn't worry about changing them until you pass 30k.
  5. Aug 21, 2009 at 7:40 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I belive those are only recomended if you are supercharged.
  6. Aug 21, 2009 at 9:31 AM
    BUDSHAD
    Chad
    Macon, Ga.
    08 TRD 4X4 SR5
    I know that you are gonna think I crazy as all hell but I have an extreme case of OCD when it comes to the maintenance of our vehicles. For instance I am changing out all the gear oils in the truck this weekend over to Royal Purple fluid. I have also purchased some of the Redline D6 ATF and will be changing that out when I find someone with a machine to do it. I know that there is a way to do it myself (and I wish I had enough confidence) but I am not too sure of how the process goes. Wish there was a good write up like the one Chris 4X4 did on the spark plugs for the ATF cooler line exchange. But yeah I thought that I would get those factory plugs out and put new ones in with the anti seize. But if yall recommend against I will wait till 30,000. Ill consider any advice in anything I do.
  7. Aug 21, 2009 at 9:43 AM
    jfr02
    jfr02 Well-Known Member
    2012 dcsb 6spd sport
    in my exsperince ngk's are the best plugs.i've used nothing but ngk's in everything dirtbikes quad's lawn mower's and my cars and trucks.if your truck did't come with platinum or iridium don't use them unless you've done some engine mods like cams,sc,or tc
  8. Aug 21, 2009 at 9:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2, but I have found the NGK's gap grows a bit more than the Denso plugs do on the 1GR-FE engines. All the gaps I have checked on the NGK's seem to be out of spec, near .050+ while the Denso plugs seem to still be within the FSM specs.
