Will these tires fit on stock?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dustin8989, Oct 22, 2020.
  1. Oct 22, 2020 at 7:31 AM
    Dustin8989
    Dustin8989 [OP] Member
    2009 tacoma single cab
    Hey guys i just bought new tires for my pick up. Will 245/75/r16s fit on my 09 single cab tacoma? Will they rub? And if so who do you guys recommend buying a lift kit from and what size lift should i do? Thanks everyone!
  2. Oct 22, 2020 at 7:53 AM
    MadRussian
    MadRussian Well-Known Member
    Metrowest MA
    2010 TRD OR AC
    Ryan2103a likes this.
  3. Oct 22, 2020 at 8:06 AM
    Ryan2103a
    Ryan2103a Well-Known Member
    SoCal
    2011 Sequoia 4x4 2022 SR 4x4
    265/75/16 or 265/70/17 is the max you can go without any rubbing. As for lifting your truck it all depends on your goals and budget. You should check out the suspension sections. Many options to choose from.
  4. Oct 22, 2020 at 8:14 AM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Are you 5 lug? That is stock size on the 6 lug reg cab
  5. Oct 22, 2020 at 8:16 AM
    Dustin8989
    I have a single cab. The factory dimensions are 215/70r15. Here is a picture, if the visual helps. Thanks for all the replies, guys!
  6. Oct 22, 2020 at 8:17 AM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    How many lugs on your wheels?
  7. Oct 22, 2020 at 8:21 AM
    Dustin8989
  8. Oct 22, 2020 at 8:34 AM
    Dustin8989
    5 lug
