Will these tires fit?
Discussion in 'Wheels & Tires' started by 05RedTaco, Jan 2, 2012.
  1. Jan 2, 2012 at 9:09 AM
    05RedTaco
    05RedTaco [OP] Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I am wondering if 285/75/16's will fit on my Taco with 2" spacer lift up front and 2" Toytec add a leaf in back? I also have front tube bumper...
  2. Jan 2, 2012 at 9:39 AM
    Discount Tire Direct
    Discount Tire Direct Wheel and Tire Guys Vendor
    285/75R16's are doable but may require some fender liner modifications to keep them from rubbing in the front. Tires are like shoes, some run larger than others so the amount of modifications required may vary. Also, if you are planning to run them on your stock wheels you may have trouble finding someone that will mount them. The stock 16" wheels are only 7" wide. 285/75R16's are only approved for wheels that are 7.5-9" wide, (8" is ideal).
