Will these tires fit?
Discussion in 'Wheels & Tires' started by boxing83190, May 11, 2010.
  1. May 11, 2010 at 3:27 PM
    boxing83190
    boxing83190 [OP] New Member
    I wanna get a OME 3in lift with 275 70 18 tires. Will 5.47in BS with -12mm offset rub the UCA?
  2. May 11, 2010 at 8:08 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Those are 33's so you should be okay. You'll definitely want the wheels with the 4.5" BS, and you still may need to trim the fender well a bit to avoid rubbing.
    If you get the 5.71 BS you will rub incredibly badly.
