Will these wheels clear trd sport calipers?
Discussion in 'Wheels & Tires' started by syl5000, Nov 13, 2012.
  1. Nov 13, 2012 at 7:46 AM
    syl5000
    syl5000 [OP] Active Member
  2. Nov 14, 2012 at 9:38 AM
    syl5000
    Bump...I'm assuming they wont fit because I don't recall seeing them on a second gen before.
  3. Nov 14, 2012 at 9:43 AM
    Manwithoutaplan
    ID
    if you ran wheel spacer it might work or you could just choose 17.0x9.0.
  4. Nov 14, 2012 at 10:25 AM
    syl5000
    The 16's specs are already aggressive for me considering I'm only running billies up front @1.75, so spacers won't work for me. I have 17's now so I wanted to try 16's this time.
  5. Nov 14, 2012 at 10:27 AM
    Manwithoutaplan
    ID
    sorry i meant wheel spacers to push the wheels away from the caliper
  6. Nov 14, 2012 at 10:38 AM
    syl5000
    Haha no prob, I knew you were referring to wheel spacer hence the caliper clearance question. What I meant was the 3.6 bs is already going to stick out past the fender a lot, so adding a spacer would just make it worse.
