Will these wheels fit my 2001 Tacoma SR5?
Discussion in 'Wheels & Tires' started by Teknishun, Jul 14, 2011.
  1. Jul 14, 2011 at 10:55 AM
    Teknishun
    Teknishun [OP] Well-Known Member
    I'm in a bind because I'm way behind and I really must to know the deal.
    Thumbs up if you get the song reference.
    Anyway my rim seems to be leaking from a serious rust issue and I'm about to do a 1000 mile drive. I can have new rims here tomorrow but I need to know the proper backspacing for my 2001 Taco. Will these rims with a 3.75" backspacing fit?
    http://www.4wheelparts.com/Wheels/R...=209&t_pt=100021&t_pl=101829&t_pn=PCW52-5183F
    Any help on this matter would be greatly appreciated.
  2. Jul 14, 2011 at 10:58 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Yes. But they are quite wide and I wouldn't recommend them unless you are running at least 12.5" wide tires. (315's)
  3. Jul 14, 2011 at 11:04 AM
    davidpick
    davidpick NWXPDTN
    David
    Snohomish, WA
    2004 Xcab 4x4 TRD
    yeah, those are very wide wheels. i'd try 15x8 if you're looking for something a bit wider than the stock 15x7 toyota wheels. with 3.75" backspacing they'll stick out a bit further than the fender flares, just fyi. and you may have to do shave the cab pinch-weld. to deal with rubbing issues.
  4. Jul 14, 2011 at 11:14 AM
    Teknishun
    Thanks guys. I believe I have 10" rims on my current 32" x 11.5" All Terrains.
    Please see photos in signature.
  5. Jul 14, 2011 at 11:16 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    that rim doesnt look like its 10 inches wide lol. but nice truck! i would go with something with 4.5 back spacing
  6. Jul 14, 2011 at 11:18 AM
    davidpick
    davidpick NWXPDTN
    David
    Snohomish, WA
    2004 Xcab 4x4 TRD
    with 15" wheels, most aftermarket wheel manufactures don't make anything with that much backspacing due to caliper clearance issues. if you go up to 16" wheels, you have many more options, but that, of course, means getting new tires as well (which is why i still have 15" wheels!).
  7. Jul 14, 2011 at 11:19 AM
    KPT
    09 Prerunner
    According to the BFG website, the 32x11.5 15's are approved for 8-10" wide rims, so you are good to go.
  8. Jul 14, 2011 at 11:21 AM
    Teknishun
    They wont rub the calipers?
  9. Jul 14, 2011 at 11:28 AM
    KPT
    09 Prerunner
    Isn't 4.5" backspacing stock for 1st gens?
  10. Jul 14, 2011 at 11:33 AM
    Teknishun
    Well, wheels are ordered! Let's hope I'm on the road by Friday evening.
    Thanks for all the help.
