Will these wheels fit?
Discussion in 'Wheels & Tires' started by trdproven, Oct 3, 2010.
  1. Oct 3, 2010 at 10:37 PM
    trdproven
    trdproven [OP] Well-Known Member
    What would be the perfect wheel fitment specs for 16", what would be the offset and bs in order to clear the suspension and stay flush with the fender?
    if anyone got the flat rota grids or te37 specs, i'd really appreciate it.
    I am looking at 16" 6x139.7 5 offset. will this work?
  2. Oct 3, 2010 at 11:23 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    1st gen or 2nd gen truck?
    what suspension?
  3. Oct 4, 2010 at 8:33 AM
    trdproven
    thanks for the reply, not sure but it is a 2003 Tacoma Prerunner 4 door 2.7L
  4. Oct 4, 2010 at 8:40 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    ur stock backspace is 4.5" so 5" will sit too far in...
    go with 4.25" so you can later clear 32" tires
  5. Oct 4, 2010 at 5:54 PM
    trdproven
    can I use a spacer? is it safe to cover that amount of space?
  6. Oct 5, 2010 at 6:36 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Wait - a 5mm offset (which is what you posted above) is NOT the same as 5" backspacking. What's the rim width?
  7. Oct 5, 2010 at 7:01 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    oh yah, offset, not backspace...
    the TE37s in 16x8 are -10 offset which is in between 4" and 4.25"
  8. Oct 6, 2010 at 2:35 AM
    trdproven
    its an 8" width, is that ok?
  9. Oct 6, 2010 at 8:27 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Uh, we've got one guy saying +5mm offset and one saying -10mm offset.
    You don't tell us what size tire you're planning on mounting.
    A -10mm offset is a fair negative offset. Expect to do a bit more trimming on a wider tire. For a 265 width tire it might be OK.
    A +5 offset is getting in close to the UCA. A 285 width tire is almost certain to rub the UCA on any rim with a positive offset. But a 265 width tire ought to fit.
    I don't think we can rule it out - I think what you've got is in the realm of "probably fits, try it out to be sure."
    EDIT: PS - I don't claim to have tried to fit a bunch of tires. But I read a *bunch* of tire fitment threads before ordering my tires and wheels.
  10. Oct 7, 2010 at 1:40 AM
    trdproven
    the tire size will just be stock size
  11. Oct 7, 2010 at 8:00 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Should be no prob. Google +Tacoma +<rim model name> to find if anyones mounted that exact rim
