Will these wheels fit?
Discussion in '5 Lug' started by Union Taco Man, Oct 13, 2012.
  1. Oct 13, 2012 at 3:32 PM
    Union Taco Man
    Union Taco Man [OP] Well-Known Member
    Austin
    Avon,IN
    06 4cyl SR5
  2. Oct 13, 2012 at 4:08 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    The 5 lug tacomas have 5x114.3 (metric) or 5x4.5 (inches) bolt pattern. The overall tire diameter you can run with the fat bob's lift is 31" regardless of wheel diameter.
  3. Oct 13, 2012 at 8:36 PM
    Union Taco Man
    Austin
    Avon,IN
    06 4cyl SR5
    Ok thanks. That is a downer though.
  4. Oct 13, 2012 at 9:25 PM
    afd23a
    The Dynamo of Dixie
    Those wheels are pretty serious. Instead of dropping that much cash on wheels with beadlocks, why not put it towards the t/c uca icon coilover lift and a set of alloys?
  5. Oct 14, 2012 at 5:54 PM
    joyotaco
    joyotaco Tenderfoot
    Ken
    Ann Arbor, MI
    98 2.4L 2wd
    Removable ladder/sailboat rack, Pioneer DEH-6400BT, clear bumper signals
    I checked out this thread hoping to deduce what the OEM wheel size on 1st gen and/or 2nd gen 5 lugs. Anyone know how to find out the OEM width and center bore size? I already know mine comes with 14" 5-114.3 lug pattern.
    Edit: And the offset.
  6. Oct 14, 2012 at 7:45 PM
    Union Taco Man
    Austin
    Avon,IN
    06 4cyl SR5
    They have cheaper rims without the beadlocks. those were just the ones that I happened to post the link to.
  7. May 29, 2013 at 4:02 PM
    Kilted Taco
    Kilted Taco Member
    Woodbridge VA
    2009 Speedway Blue XRunner
    Is this true for the 2009 XRunner?
    From reading other threads I see they apparently come with an 18 wheel as stock but I can't find information on the lug pattern.
    Any info would be greatly appreciated.:D
  8. May 30, 2013 at 6:45 AM
    MowTaco
    MowTaco Well-Known Member
    South Dakota
    03 GMC Sierra
    From everything I've seen the xrunners use the same lug pattern as other 5 lug tacos
    If you have one you can just go measure the distance between the lug nuts and determine it for sure
