will these wheels fit?
Discussion in 'Wheels & Tires' started by motoxmann, Feb 18, 2010.
  1. Feb 18, 2010 at 1:22 AM
    motoxmann
    motoxmann [OP] Well-Known Member
    Bay Area
    2009 TRD Sport
    Fox 2.5 RR coilovers, Fox 2.0 piggyback rear, toytec aal, TC UCA's, weathertec liners, Wet Okoles, grillcraft in the mail
    So heres the deal. Ive got an 09 sport that i've been slowly building. About 6 months ago I put put on fox shocks front/rear with TC uca's. Since then I've been saving for some wheels and I was planning on going with procomp 7089's. I ran across these the other day and liked the look of them.
    http://www.4wheelparts.com/Wheels/P...k.aspx?t_c=11&t_s=210&t_pt=100073&t_pl=101929
    They're new procomp 7047, and apparently they only come in 17x9's with a 4.75 backspace and a -6mm offset. Ultimately, when funds permit and my stockers are done i'm planning on running 285/70/17 km2's. Will these rims work without hitting the uca's? Do i even need to worry about that since they're not the stock uca's? I've read conflicting things and don't know what to believe. Thanks!
  2. Feb 19, 2010 at 12:48 AM
    motoxmann
    Bay Area
    2009 TRD Sport
  3. Feb 19, 2010 at 5:26 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Are you lifted? I am assuming yes since you went with UCAs and Fox shocks. They look like they will fit except the backspacing needs to be a hair smaller or you will rub.
  4. Feb 19, 2010 at 5:35 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    ^^ Going to be close on the front of the UCA'a at full turn. For reference the sport rims are 5.5" backspacing.
  5. Feb 19, 2010 at 11:46 AM
    motoxmann
    Bay Area
    2009 TRD Sport
    thanks for the replies guys. Yeah the truck is lifted about 2.5-3 inches and a 2 inch AAL in the back. So it sounds like I should go with the 7089's for something with a 4.5 inch backspace. Since there's only a difference of .25" is there the potential for a 4.5 backspace to hit as well? Doesnt seem like that big of a difference.
    Also, was looking at the ATX artilleries as well and they have a 4.52" backspace but also only seem to come in 17x9. Will 9 inch width be fine or would that cause a problem?
    thanks
  6. Feb 19, 2010 at 11:52 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    4.5" BS with 285's is what most lifted guys run. I believe you will still have to trim some of the fender well plastic though.
  7. Feb 19, 2010 at 12:04 PM
    motoxmann
    Bay Area
    2009 TRD Sport
    yeah im sure i'll have to trim the plsatic, and thats cool. I just want to make sure i dont hit the uca. thanks again
