Will these wheels fit..??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hogsnatcher, Dec 3, 2023.
  1. Dec 3, 2023 at 7:45 AM
    Hogsnatcher
    Hogsnatcher [OP] Member
    2013 Tacoma Sport - Long bed
  2. Dec 3, 2023 at 7:55 AM
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
  3. Dec 3, 2023 at 8:02 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
  4. Dec 3, 2023 at 8:04 AM
    Hogsnatcher
    will ride height need be adjusted to compensate?
  5. Dec 3, 2023 at 8:08 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    LOLLY likes this.
  6. Dec 3, 2023 at 8:08 AM
    Beer:30
    Kevin
    2016 DCSB OR V6 4X4
    Possibly. You may need a small lift to prevent rubbing since that tire size is taller than stock.
  7. Dec 3, 2023 at 8:10 AM
    LOLLY
    LOLLY Well-Known Member
    Alfredo
    Norwalk, CA
    '05 Tacoma DCLB TRD Sport (RIP) Now '21 TRD Off-Road
    X2 for FN wheels. Fantastic guy to work with. I bought the five shooters from him
  8. Dec 3, 2023 at 8:11 AM
    wi_taco
    Adam
    SE Wisconsin
    False. Lift does not equal clearance for IFS.
    Rock Lobster and Ricardo13x like this.
  9. Dec 3, 2023 at 8:22 AM
    Beer:30
    Kevin
    2016 DCSB OR V6 4X4
    My 3rd gen rubbed on the mud flaps until I added a small lift, but sure, okay.
  10. Dec 3, 2023 at 8:26 AM
    wi_taco
    Adam
    SE Wisconsin
    And just because it doesn’t rub at ride height doesn’t mean it won’t rub when the suspension cycles. This is one of the most common questions on TacomaWorld, I’m not claiming anything that hasn’t been beaten to death a million times before. Feel free to read in the Suspension subforum and you’ll find the same answer. But hey if all you do is drive to the mall then sure spend more money and upgrade suspension.
    Cetacean Sensation likes this.
  11. Dec 3, 2023 at 8:34 AM
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
    Those wheels can be purchased from a dealer for a lot less than that Amazon seller fyi.
    If you don’t mind buying used or “brand new take off” you can usually find them for around half that.
  12. Dec 3, 2023 at 8:39 AM
    Hogsnatcher
  13. Dec 3, 2023 at 8:42 AM
    Hogsnatcher
    How much lift was needed to clear??
  14. Dec 3, 2023 at 9:26 AM
    Beer:30
    Kevin
    2016 DCSB OR V6 4X4
    About an inch. I left the rear at stock height and added enough lift to the front to take it almost level but left just a smidge of rake. And I'm running the same wheels and tire size you are looking at. But I have 3rd gen and you have a 2nd, so you may need to go higher to clear.
    @wi_taco is correct in that when off road you may still get into a rubbing situation (usually when in reverse with the steering at full lock), but a lift will solve it for the 99.9% day-to-day backing out of the driveway rubbing. Understanding that you are willing to lift a bit if you have to, I'd install the wheels and tires and see how it goes. They may clear fine without any need to change anything else. If not, throw some Bilstein 5100's on and call it a day. I assumed that you are wanting these wheels and tires mainly for looks and not off-road performance, so who cares about some occasional rubbing the three times a year you might take it off-road?
  15. Dec 3, 2023 at 9:31 AM
    Hogsnatcher
    I’m 58 and will only use this truck as a dedicated fly fishing drift boat pulling rig. Gravel roads and boat ramps will be the most extreme. Mostly road and highway use. NO off roading.
    It already has Toytec Boss Coil overs that allegedly can adjust to 1”
  16. Dec 3, 2023 at 9:31 AM
    Beer:30
    Kevin
    2016 DCSB OR V6 4X4
    Now we're getting somewhere. Your first comment wasn't all that helpful, but now that you've added some context, we can see the nuance. The lift might not do shit at full stuff, assuming the OP ever finds himself in that situation, but it will prevent the rubbing he may otherwise experience the 365 days a year he has to back out of his driveway. In the end, I agree with you in that if you're rubbing at ride height, simply adding a lift won't solve it under all circumstances. But it probably will solve it under most circumstances, and for most of us, that's good enough.
    winkel likes this.
  17. Dec 3, 2023 at 9:32 AM
    Beer:30
    Kevin
    2016 DCSB OR V6 4X4
    Oh, there you go. Worst case is you might have to crank up the preload a bit on those CO's.
    winkel likes this.
  18. Dec 3, 2023 at 9:36 AM
    Hogsnatcher
    Well, right now they are significantly cranked with too much preload ive been told. The previous owner did so to run 18” wheels and mud tire.
    I need to make this rig more “normal”
  19. Dec 3, 2023 at 9:37 AM
    Beer:30
    Kevin
    2016 DCSB OR V6 4X4
    If that's the case, I doubt the wheel/tire combo you're looking at will rub since you're already lifted. You may even find you can drop it some.
  20. Dec 3, 2023 at 9:40 AM
    Hogsnatcher
    that’s what I’m wanting to do! Drop it from this nonsense and arrive at a truck that sits like a TRD Pro.
    TheFactor likes this.
