Will these wheels work for my 1995 Tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 95Tacoma4x4, Dec 15, 2021.
  1. Dec 15, 2021 at 1:38 PM
    95Tacoma4x4
    95Tacoma4x4 [OP] New Member
    1995 Toyota Tacoma Extra Cab 4x4
    2 Inch Old Man Emu lift with 32x11.5 R15LT BFGoodrich Tires
  2. Dec 15, 2021 at 2:05 PM
    ijm01PR
    ijm01PR Well-Known Member
    Alex
    Indiana
    01 DC Prerunner (4x4 TBD)
    Ome 881s w/ 5100s and jba ucas 2” pro comp AAL with 5100s in the rear
    The bolt pattern is correct. Just check the backspacing on it. I bought some american racing rims That I put on my first tacoma and they rubbed the brake calipers real bad. Not sure what the backspacing was on those. Been like 10 years. I’d do some thread surfing just to check the backspacing.
    CS_AR likes this.
  3. Dec 15, 2021 at 2:32 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Can't speak to anything fitment wise. You can run lug centric wheels with acorn lug nuts.
    CS_AR likes this.
  4. Dec 15, 2021 at 2:44 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    I had a backspacing issue with some similar looking wheels that rubbed the caliper. I had to get spacers. Not sure about these.
    If you get the wheels, roll them across a smooth garage floor to see if they will roll straight without wobbling. Some of the metal wheels from China are "out of round" and really cannot be balanced.
  5. Dec 15, 2021 at 9:07 PM
    Halena Molokai
    Halena Molokai Well-Known Member
    Black 2016 TRD DCSB OR 4x4 MT6
    BFG KO2 265/70/17 Moto Metal 17x 9 -12mm ToyTec Boss 2.0 lift Kit Wet Okole, Ceramic tint 35% Bakflip F1 Flowmaster Exhaust Single in /Dual out with 3"stainless tips DashMat Covercraft Custom windshield shade Tilt Alarm Weatherbeater Mats Diode Dynamic LED upgrade to interior OEM Bed Mat OEM 5" Chrome Side Steps
    Your offset is -12mm and I believe you might have to run wheel spacers. Some calipers are diffrent in years on the first gen. On a 2003 4x4, the caliper interferes with a 15x8 pro comp wheel -19mm offset. If your truck is 5 lug it might work but not too sure.You can buy hub centric rings 108mm to a 106.1 for the 1st gen. $.02
