Will they fit without spacers?
Discussion in 'Wheels & Tires' started by Tigers Win, Oct 29, 2014.
  1. Oct 29, 2014 at 9:17 AM
    Tigers Win
    Tigers Win [OP] Member
    SW Mississippi
    11 TRD 4door 4x4 White
    I just bought a 2011 4 door Tacoma with stock 16"rims and 255/85/16 tires on it. The front shocks have what looks like 1 1/2" spacers on them. Im wondering if I can run this tire with out the spacer installed. The tires have about 25k miles left so I really dont want to change them until there semi warn out but I dont like the look it has right now nor do I like getting everyones high beams every time I pass someone at night.
    My goal would be remove spacers and run these tires until there toast and then go with a shorter/wider tire.
    Thanks and I love the TW site..
  2. Oct 29, 2014 at 9:20 AM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    They would no doubt rub... Keep them until they are worn Id say. That's a tall tire and will rub
    Maybe try selling them?
  3. Oct 29, 2014 at 9:23 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I'm guessing the rear isn't lifted. You could put an add a leaf in the back to return the truck to stock rake.
  4. Oct 29, 2014 at 9:24 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Or just take it out, sell the tires for a few bucks, and put on a normal size tire.
  5. Oct 29, 2014 at 9:29 AM
    Tigers Win
    SW Mississippi
    Your right Bmoose, the rear is not lifted. Not sure which direction I want to go with it yet but I do know I dont like the front higher then the rear..
  6. Oct 29, 2014 at 9:34 AM
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    if I remember correctly 265/75 and 255/85 would be the same ish diameter right? with the 255 being slightly narrower im just not seeing why it would....
  7. Oct 29, 2014 at 9:38 AM
    teneighty
    255/85 are about 1.5" taller
    If you're driving around on pavement and never leave the road they might fit OP. Not sure about fully turned wheel... You would probably definitely rub at full lock and would have to adjust for a shorter turn radius
  8. Oct 29, 2014 at 3:33 PM
    TylerMorton
    TylerMorton Member
    Tyler
    Mooresville nc
    I can't remember what size comes stock. But I woukd Imagen it would be something like 265/75/16
  9. Oct 29, 2014 at 3:36 PM
    teneighty
    265/70/16
  10. Oct 29, 2014 at 3:40 PM
    TylerMorton
    TylerMorton Member
    Tyler
    Mooresville nc
    Damn I was close.
  11. Oct 30, 2014 at 3:13 AM
    Tigers Win
    SW Mississippi
    I figured they probably were adjustable but im more concerned with lowering the front end back to the stock look for now. Guess Ill have to bite the bullet and get a new set of tires.. Thanks..
  12. Oct 30, 2014 at 7:29 AM
    1 Bored Clerk
    1 Bored Clerk Well-Known Member
    Vancouver, WA
    '13 4x4 AC TRD OR
    On stock rims, many people are able to run the 255/85 with no rub...even when flexing. Do a little searching if you want. I would t bother selling the tires. Take the lift out and see what happens. If it rubs, then sell them. If it doesn't then just enjoy the ground clearance.
  13. Oct 30, 2014 at 7:48 AM
    teneighty
    With a lift
  14. Oct 30, 2014 at 8:09 AM
    1 Bored Clerk
    Vancouver, WA
    '13 4x4 AC TRD OR
    No. Without a lift in many occasions. Lifts that do nothin but change ride height have no bearing on whether or not a tire will fit. The wheel still travels the same arc and bottoms out on the same bump stop so if a tire fits, it fits. A lift just makes tires that are going to rub anyway rub less on the street.
  15. Oct 30, 2014 at 8:16 AM
    teneighty
    :eek: :confused:
    :der:
  16. Oct 30, 2014 at 8:18 AM
    1 Bored Clerk
    Vancouver, WA
    '13 4x4 AC TRD OR
    Okay. Feel free to be misinformed. :rolleyes:
  17. Oct 30, 2014 at 8:20 AM
    teneighty
    I have the same size (255/80/17)... Sure I could drive straight down the road with no lift but that's it.
  18. Oct 30, 2014 at 8:30 AM
    1 Bored Clerk
    Vancouver, WA
    '13 4x4 AC TRD OR
    Hence my statement 'on many occasions'. What rubs and what fits seems to be very specific to each individual truck. My guess is that manufacturing tolerances and alignment has a lot to do with it since the 255/85's are a very tight fit even when they do fit.
    Also, you run spacers, don't you? That makes the rubbing worse because the arc that the tire travels is wider than it is when stock. 255/85's fit a lot of trucks on stock wheels with no spacers.
  19. Oct 30, 2014 at 8:37 AM
    teneighty
    Only because I was rubbing on my UCA. Why that was I have no idea... I had 275's with no issues
    I won't be able to put my flaps back on for winter either I don't believe.
  20. Oct 30, 2014 at 8:39 AM
    1 Bored Clerk
    Vancouver, WA
    '13 4x4 AC TRD OR
    Haha, yeah, I'm pretty sure flaps have to go either way. Weird that your 255's were rubbing the UCA but not the 275's.
