Will they fit
Discussion in 'Wheels & Tires' started by Dewman4, Mar 6, 2011.
  1. Mar 6, 2011 at 12:27 PM
    Dewman4
    Dewman4 [OP] Well-Known Member
    Andy
    Haymarket, VA
    2011 Tacoma TRD Sport
    black badges, aFe intake
    My father in law is looking to give me some rims and tires to put on my truck. I am not sure if they will fit or not so I was hoping you all could help answer that question. I am going to put a 3" lift on my truck. The rims are 20s and the tires are 285/50R20. Will these fit under a 3" lift with no rubbing?
  2. Mar 6, 2011 at 12:27 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    might rub a little, nothing a bit of trimming wont fix
  3. Mar 6, 2011 at 12:39 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX or College Station, TX
    08 Prerunner V6 Black
    Viper Alarm, In Pro Car Wear L.E.D. Tail Lights, Fog Lights, ScanGuageII, AvidOffroad Light Bar, Ammo Box Mod, Tailgate Theft Prevention Mod, Satoshi Grill, Hella 500ff behind the grill, blendmount, Cruise Control Mod, Fog Light Mod, 5100's @1.75, Toytec TSB AAL 1.5".
    I think they will. They are just wider than normal. I think with 3" you should be fine.
  4. Mar 6, 2011 at 12:56 PM
    Dewman4
    Andy
    Haymarket, VA
    What type of trimming might i have to do. I don't have a lot of experience with these types of things.
  5. Mar 6, 2011 at 1:13 PM
    topgun155
    Zack
    If you do have to trim. It will just require removing the thin plastic liner in the wheel well. I have heeard that a box cutter works great. Normally if you do rub it will be at full lock in reverse.
