Will this amp work?
Discussion in 'Audio & Video' started by chaos316, Nov 3, 2011.
  1. Nov 3, 2011 at 7:55 PM
    chaos316
    chaos316 [OP] Well-Known Member
    JJ
    Wichita, KS
    2011 Super White DCLB Sport 4x4 3" Spacer lif
    3" Revtek Spacer lift and aal, 18" Gear Alloy wheels, Nitto terra grapplers
  2. Nov 3, 2011 at 7:58 PM
    chaos316
    JJ
    Wichita, KS
    or a memphis 16pr1.500?
  3. Nov 3, 2011 at 8:00 PM
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x on 5100s / LR UCA Wheelers 3 leaf progreaaive AAL 275/70/17 KO 2's on 17" fuel Hostage no rubbing
    maybe u should get a 1k watt amp because if ur runnin 2 10's u might be blowing alot of fuses in that amp if u try to push it to hard
  4. Nov 3, 2011 at 8:07 PM
    fishntaco
    fishntaco Well-Known Member
    Josh
    Mobile Al
    08 Silver Streak DCLB Prerunner Sport
    Whichever amp you choose, make sure it is stable at 3ohms otherwise you wont be able to run the 13tw5 very effectively.
  5. Nov 3, 2011 at 8:07 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    What are the the subs impedance? If they are the D4's, 4 ohms, then that amp will be fine It will in fact over power the subs but over powering with it turned down is better than under power with the amp turned all the way up. It's due to clipping btw, if your amp is smaller than what your subs are rated for it won't blow the sub unless you turn it up to where it is clipping.
  6. Nov 5, 2011 at 8:40 AM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    everyone figures if they send 600 watts to a 500 watt rated driver it will explode in their face.
  7. Nov 5, 2011 at 10:18 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    +1
