will this be all i need to lift my truck
Discussion in '1st Gen. Tacomas (1995-2004)' started by mackattack07, Apr 21, 2011.
  1. Apr 21, 2011 at 2:06 PM
    mackattack07
    mackattack07 [OP] Well-Known Member
    william
    Jacksonville NC/Graceville FL
    99 Prerunner 3.4/2000 4Runner3.4/85 Pickup22R
    is this all i need or are there other little odds and ends i would need to do it right the first time
    LR Upper control arms for 95.5-04 Tacoma and 96-02 4Runner
    25460 $449.99 $449.99
    OME Tacoma suspension
    Front coil options: 883 coils (Med)
    Front top plate spacers: No top plate spacers (882&883 coils) (- $59.00)
    Rear lift options: OME complete rear springs (98-04 Tacoma only) (+ $399.00)
    Rear shocks: 60062 (Normal valving)
    Front diff drop kit: Delete front diff drop kit (2WD) (- $29.00)
    Front shock Assembly: Unassembled
    ADD rear shock stone guards (Pair): NO OME-9504TAC $1 010.99 $1 010.99
    Subtotal: $1 460.98
    Total: $1 460.98
  2. Apr 21, 2011 at 2:40 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    33's,armor,crawler,dents, ect
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
  3. Apr 21, 2011 at 3:12 PM
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    Your prices seem a bit high... what site are you spec'ing this from?
  4. Apr 21, 2011 at 3:33 PM
    chvymechanic
    chvymechanic Well-Known Member
    Thomas
    New Hampshire
    04 Limited TRD Off Road 4x4 Xtra Cab
    Stuff and Thangs
    Fat Bob's Garage has the LR UCA for $379 plus shipping to save you a few bucks on that order.
  5. Apr 21, 2011 at 5:42 PM
    mackattack07
    william
    i think its off of toyotec ill find em cheaper but as far as parts
  6. Apr 21, 2011 at 5:46 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    It says OME tacoma susp, Does that mean you got the shackles to go with it? You need new ubolts to go with those OME springs, and i recomend getting extra bolts for the front of the leaf springs you can return them if you dont need em. Those things hate to come out without a cutoff wheel;)
  7. Apr 22, 2011 at 2:58 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    I would also get greasable shackles and spring pins, new U-bolts, and leaf spring bushing kits. If you're replacing the rear suspension, you may as well do all the hardware too.
