Will this FIT!!!!????
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaNJ, Nov 5, 2010.
  1. Nov 5, 2010 at 1:42 PM
    TacomaNJ
    TacomaNJ [OP] Well-Known Member
    Central Jersey
    2001 TRD SR5 Tacoma Ext.Cab
    http://jerseyshore.craigslist.org/pts/2042341767.html
    The guy said its 6 feet long, and that it was previously on a Colorado...
    I know that the length works, but is there reason to believe that it may not be wide enough or too wide for my tacoma?
    ASAP info appreciated as I am on my way to take a look at it now.
  2. Nov 5, 2010 at 7:29 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    It'll likely fit but probably wont match up with the back of your cab very well.
