will this give me what i want?
Discussion in 'Toytec Lifts' started by nhgranite, Dec 6, 2010.
  1. Dec 6, 2010 at 6:00 AM
    nhgranite
    nhgranite [OP] Well-Known Member
    N.H
    fisher plow
    i want a lift and 886 springs for my plow. my question is this. i want to order billies all round, 2 inch aal w/886 springs for the plow. would this combo work? will the front shocks set at 2.5 with the 886 springs make the nose sit high unloaded? thanks.
  2. Dec 6, 2010 at 6:13 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    I doubt you'll even get the CO assembled with it at the 2.5 setting with 886's. I would go higher than the .85 setting. It's going to be stiff as hell.
  3. Dec 6, 2010 at 8:51 AM
    nhgranite
    N.H
    fisher plow
    ok i don't understand really what you said. i agree it will be stiff. to stiff to live with? what do you mean go high than .85 and co assembled? was it supposed to be ca like in control arm? thanks.
  4. Dec 6, 2010 at 8:57 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    My bad...typo on my part. I mean I wouldn't go higher than .85 on the 5100 with the 886 spring. And what I meant was I think it is going to hard as hell to compress a 3" lift spring and then try to put it on the 5100 2.5" setting. Plus, you will get way more than 3" of lift which is going to create serious problems. Either keep the 5100 at the .85 or lower, or just use the OME shock. I would suggest just using the OME because it is valved for that shock.
  5. Dec 6, 2010 at 11:03 AM
    nhgranite
    N.H
    fisher plow
    so the 886 is a lift spring. wasn't sure on that. no need to adjust the shock at all then right? just need one with the right travel.
  6. Dec 6, 2010 at 11:05 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Yes, it's a lift spring. The OME or 5100 with both have the right travel.
  7. Dec 6, 2010 at 12:47 PM
    nhgranite
    N.H
    fisher plow
    cool, thanks
  8. Dec 6, 2010 at 1:05 PM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    He is right. Even if you could get it assembled the retained clip would probably pop off as soon as you put any real torque on the shocks.
  9. Dec 7, 2010 at 3:06 PM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    I would go with the OME shock over the 5100's. OME only recommends using their shocks with their coils. If you do use the 5100's, only set them above the lowest stock notch.
  10. Dec 8, 2010 at 4:50 AM
    nhgranite
    N.H
    fisher plow
    would that work with a lift spring. don't you need to increase travel?
