will this impact wrench work???
Discussion in 'Garage / Workshop' started by gupster88, Mar 24, 2010.
  1. Mar 24, 2010 at 11:44 AM
    gupster88
    gupster88 [OP] Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    ok so i need an impact wrench so i can rotate my tires and what not with routine maintenance on my truck. i've been looking at a craftsman 19.2V, 200 ft-lbs of torque battery powered portable impact wrench kit. its cheaper than having to get a compressor, impact wrench, then hoses and all that plus i dont have the space for a compressor where i live.
    what im getting at is that will the impact wrench i mentioned fit my needs, or will i need to get a full kit with more torque?
  2. Mar 24, 2010 at 11:45 AM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    yes. my cousin has same one but you can only tighten and loosen them then you will need a torque wrench to torque to spec and you cant run them them tight with it neither
  3. Mar 24, 2010 at 12:23 PM
    gupster88
    Brett
    Almost Heaven, WV
    Stock
    i have a torque wrench so i should be good there. as long as i can loosen up and tighten my lug nuts thats all i need it for
  4. Mar 24, 2010 at 12:38 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Yes. Remember that since you religiously used your torque wrench at 83 ft/lbs (I do 90 on mine) and used anti-seize lube :D , You will only need just over that poundage to remove them. DO NOT USE THE IMPACT WRENCH TO TIGHTEN THE NUTS - NEVER!
    I have a small craftsman impact wrench that maxes out at 80 ft/lbs. with 90 lbs of air. It won't take them off. I was driving down the street a few years ago and saw a garage sale. I found a Matco 600 lbs wrench for $25. What a deal! I had a friend borrow it to remove some rusted on nuts on his full size tractor wheels. It will either remove the nut or break the bolt. Either way that sucker's coming off. I use the Matco to remove lugs and even used it to get the 180 ft/lbs. pulley nut off my Acura with ease. I pretty much only use it in reverse.
  5. Mar 24, 2010 at 12:47 PM
    gupster88
    Brett
    Almost Heaven, WV
    Stock
    thanks for the heads up! i think im gonna bite on the impact wrench then
