Will this lift combo work?
Discussion in 'Suspension' started by grubburg, Feb 28, 2015.
  1. Feb 28, 2015 at 2:39 PM
    grubburg
    grubburg [OP] Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    Bilstein 5100 at 1.75 up front and 1.5 inch add a leaf revtec in the back.
    do i need anything else, other than an alignment?
    from what i read, this should do it, as long as i don't put the struts at 2.5.
  2. Feb 28, 2015 at 2:41 PM
    grubburg
    2019 TRD OR MT
    also going with the nitto grappler 2's 265/70/17 and american outlaw hollywood rims. should look pretty sweet!
  3. Mar 2, 2015 at 9:38 AM
    grubburg
    2019 TRD OR MT
    anyone?
  4. Mar 2, 2015 at 9:47 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Alignment should be it bro, after you put the new wheels and tires on would be better. But definitely after the lift
  5. Mar 2, 2015 at 9:48 AM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    yes i have that lift and tire size its perfect. if you have a 4 leaf stock rear leaf pack then add the 1.5 u will have alot of rake. so if you have 4 of them back there u dont need it.
  6. Mar 2, 2015 at 10:46 PM
    grubburg
    2019 TRD OR MT
    1.5 up in the back and 1.85 up in the front. shouldn't the rake be decreased?
  7. Mar 3, 2015 at 11:23 AM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    stock rear is 1 inch higher usually. Also depends on if you have a 3 leaf pack in the rear or the 4 leaf, if you have the 4 leaf u dont really need the aal if you have the 3 leaf then you do.
  8. Mar 3, 2015 at 11:37 AM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    the 4 leaf TSB pack didn't provide me any lift over the stock 3 leaf pack.
    OP should be fine with the specified lift, and those tires should fit without issue before lifting if he so chooses.
    However, I think I am one of the 5% of people who rub with that size and I have a 2" Ironman lift.
    I'm assuming that the OP is driving a DCSB, as that seems to be the most popular combination. His experience could be different if he is driving an ACLB or SCLB.
  9. Mar 4, 2015 at 5:23 AM
    grubburg
    2019 TRD OR MT
    yeah i'm rolling an access cab sr5 4x4 2014
