Will this lift kit give me a legitimate 3" lift with top plate spacers?
Discussion in 'Suspension' started by pivey14, Jan 5, 2013.
  1. Jan 5, 2013 at 1:24 PM
    pivey14
    pivey14 [OP] I'm A Grinder
    Patrick
    Baton Rouge, LA
    '11 DC Base PreRunner
    See Build Thread
  2. Jan 5, 2013 at 2:47 PM
    pivey14
    Patrick
    Baton Rouge, LA
    See Build Thread
    Anyone?
  3. Jan 5, 2013 at 2:53 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Don't get a spacer lift. The coilover will bottom out before contacting the bump stops. Eventually, the strut breaks off at the bottom end.
  4. Jan 5, 2013 at 2:59 PM
    pivey14
    Patrick
    Baton Rouge, LA
    See Build Thread
    It isn't a spacer lift...Its Bilstein 5100's with Eibach Coils and a top plate spacer.
  5. Jan 5, 2013 at 3:00 PM
    pivey14
    Patrick
    Baton Rouge, LA
    See Build Thread
    You have to click the link. Adding a top plate spacer is an option and I'm wanting to know if adding the spacer will actually lift it to 3".
  6. Jan 5, 2013 at 3:02 PM
    mtwil9
    mtwil9 Well-Known Member
    Birmingham
    12 TRD Off Road 4x4
    Bilstein 5100 F&R Eibach at .85 with top plate spacer, 1.5 AAL,LR UCA's Tinted Windows, Weathertech Floormats, Ultra Gauge, 20" light bar behind grill
    I have this lift with the top plate spacers with 285 75 16 BFG A/T. No rubbing so far but haven't taken it offroad yet.
  7. Jan 5, 2013 at 3:03 PM
    pivey14
    Patrick
    Baton Rouge, LA
    See Build Thread
    That is exactly what I want. :cheers:
  8. Jan 5, 2013 at 3:06 PM
    KodiakToyTRD
    KodiakToyTRD Well-Known Member
    CO
    2013 Scion FR-S Whiteout
    This lift uses Bilstein shocks, the OME lift uses different shocks.
    I would advise against getting the top plate spacers, research shows that spacers are the point at which your lift will fail.
    I hope you didn't buy the tires then figure out how much you need to lift to put them on there. Lift first, tires second.
    No spacers.
  9. Jan 5, 2013 at 3:09 PM
    pivey14
    Patrick
    Baton Rouge, LA
    See Build Thread
    I haven't purchased anything yet. How can I achieve 3" without using a top plate spacer?
  10. Jan 5, 2013 at 3:12 PM
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Sin City
    08 TRD O/R DC Prerunner
    I have this lift with the the 1/4" spacer to correct the taco lean and I just put 285's on. All that was required with the lift was a cab mount chop and some trimming of the plastics in the wheel well
  11. Jan 5, 2013 at 3:12 PM
    KodiakToyTRD
    CO
    Get the adjustable coilovers and rear leaf springs.
  12. Jan 5, 2013 at 3:13 PM
    bzzr2
    bzzr2 Well-Known Member
    the small top plate spacers that toytec sells are fine to put on top if you don't get enough lift. you can not use an in coil spacer with this setup. the in coil spacers are where problems may occur.
  13. Jan 5, 2013 at 3:38 PM
    claymore
    claymore Well-Known Member
    Clay
    ABQ New Mexico
    2012 Offroad
    TRD cat back exhaust, console vault(for my little friend),Pop and Lock, Bak Flip G2, Weather Tech window covers, LED inside and out, DTRL Anytime, Grillcraft Grill, BAMF Light Bar with Hella 500s and Blitzpro 15D, Eibach with 5100's all around set at .85 and top plate spacers, LR UCA's, toytec 2" add a leaf, Duratrack 285 75 16, ABS kill switch, Aux reverse lights, Blue Sea Aux fuse block, ImMrYo Bracket, LED Bedlights, Ultra Gauge,
    I used this same lift and got 3". I put the spacers in on both sides and the 1/4" in on the driver side (2 spacers). It has been great, and I have 285's.
  14. Jan 5, 2013 at 3:53 PM
    pivey14
    Patrick
    Baton Rouge, LA
    See Build Thread
    I thought this lift was the same thing as the coil-overs except it isn't pre-assembled?
  15. Jan 5, 2013 at 3:56 PM
    KodiakToyTRD
    CO
    Go to the Toytec website and look under front lifts. You'll see assembled adjustable coilovers and assembly required adjustable coilovers.
    Then go to rear lifts, you'll see the leaf packs.
    Sadly they don't make them all together in a kit.
  16. Jan 5, 2013 at 8:48 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    The adjustables are the best bet to get an even lift. Just make sure you put copper antiseize on the threads before install. Don't go over 3", or the shocks can be damaged from the"slide hammer" effect from the shocks stopping suspension travel.
    I need to find a solution for this. I am over 3" with an one lift on a reg cab and 4cyl:/
