will this locker work on my 09?
Discussion in 'Performance and Tuning' started by taco_man, May 17, 2010.
  1. May 17, 2010 at 4:27 PM
    taco_man
    taco_man [OP] Well-Known Member
    Austin
    Houston
    09 texas edition
    Borla exhaust, K&N intake, Full sound system
  2. May 17, 2010 at 4:36 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    first one is for the rear, the middle is for a land cruiser and the rest idk
  3. May 17, 2010 at 5:54 PM
    taco_man
    Austin
    Houston
    09 texas edition
    well thats where im gonna put the locker. im just a pre runner. do i need anything else to make this locker work?
  4. May 17, 2010 at 10:25 PM
    08pretaco
    Oliver
    az
    Nopr. You need a locker and I am pretty sure you will need a gear install kit, I'm not 100% sure though. Only reason I say I think you need the install kit is because you are taking out the assembly, swapping the gears to another assembly, then reinstalling. Someone else will probably chime in though but look into spending another 100-250 bucks for the install kit. Also if your ever thinking of running larger tires and want to do. Agear swap, now is definetely the best time to do it. Saves you a great amount of money ion the long reun
  5. May 18, 2010 at 5:03 AM
    taco_man
    Austin
    Houston
    09 texas edition
    ya im planning on running 4.88 since im on 37s
  6. May 18, 2010 at 5:07 AM
    JTO
    JTO Well-Known Member
    San Diego
    PreRunner Sport
    so all you need to install a locker is buy one of these things and install it?
  7. May 18, 2010 at 7:15 AM
    08pretaco
    Oliver
    az
    Good! If you have the money id recommend getting an arb selectable locker.
  8. May 18, 2010 at 7:24 AM
    taco_man
    Austin
    Houston
    09 texas edition
    im not a fan of selectables... a bud of mine was muddin once and needed it and when he went to turn it on it didnt come on...
  9. May 18, 2010 at 8:02 AM
    08pretaco
    Oliver
    az
    Not to sound mean but like anything else in life things need maintenance. Did he regularly check to make sure everything was in working order before he went out? Inspected air lines and such?
    In any case detroits are a good choice for a full time!!
  10. May 18, 2010 at 1:15 PM
    taco_man
    Austin
    Houston
    09 texas edition
    ya i know. the line was bad on it. im just biased.
