Will this setup work????
Discussion in 'Suspension' started by PETEREDGE, Jun 22, 2012.
  1. Jun 22, 2012 at 2:38 PM
    PETEREDGE
    PETEREDGE [OP] Well-Known Member
    PETER
    TEXAS
    2012 BAJA BLACK 4X4
    ARB FRONT BUMPER...16x8 SR8 RIMS ,YOKAHAMA MT'S,DEMELLO SLIDERS,UPGRADED SOUND SYSTEM...
    I have an 08 dbl cab sport that has a spacer lift and an aal on it(had it when i bought it).I want to change it to billy's all around set front to 0.85,use stock springs and put a 1/2 or 1/4 spacer on top to achieve 3" of lift.My question is can i use stock springs without having to buy new ones???Any info will be greatly appreciated...
  2. Jun 22, 2012 at 2:46 PM
    Large
    Large Red
    Yes.
  3. Jun 22, 2012 at 2:46 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    No...dont combine lifts is what I was always told.
  4. Jun 22, 2012 at 2:48 PM
    PETEREDGE
    PETER
    TEXAS
    2012 BAJA BLACK 4X4
    not really combining it's kinda the same as the Toytec lift just without the new springs and should be cheaper.
  5. Jun 22, 2012 at 2:49 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    How do you figure setting the Bilstein 5100 at .85 and a 1/2" top plate spacer will give you 3" of lift?
  6. Jun 22, 2012 at 2:54 PM
    PETEREDGE
    PETER
    TEXAS
    2012 BAJA BLACK 4X4
    The thing is im not sure thats why i need help with this.I just dont want a spacer lift anymore.
  7. Jun 22, 2012 at 3:08 PM
    PETEREDGE
    PETER
    TEXAS
    2012 BAJA BLACK 4X4
    so would the stock coils get me 2 /12 at least
  8. Jun 22, 2012 at 3:11 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    If you set them at 2.5 they will if not just go OME 885x coils....
  9. Jun 22, 2012 at 3:13 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    This
  10. Jun 22, 2012 at 3:13 PM
    KenLyns
    Belly of the Beast
    The Bilstein 5100 has a 2.5" perch setting that is designed to give you 2.5" lift with stock coils.
    Unless you get aftermarket upper control arms, going higher than 2.5" lift is not recommended.
  11. Jun 22, 2012 at 3:16 PM
    PETEREDGE
    PETER
    TEXAS
    2012 BAJA BLACK 4X4
    Ok so will the ride improve over the spacer??
  12. Jun 22, 2012 at 3:17 PM
    BulletToothTony
  13. Jun 22, 2012 at 3:21 PM
    PETEREDGE
    PETER
    TEXAS
    2012 BAJA BLACK 4X4
    Cool deal sounds good..i checked on Toytec's site and the bilstein lift is backordered..ill proberly get them from Downsouth...
  14. Jun 22, 2012 at 3:23 PM
    BulletToothTony
    Yes order from downsouth they offer tw discount and free shipping :D
  15. Jun 22, 2012 at 3:29 PM
    PETEREDGE
    PETER
    TEXAS
    2012 BAJA BLACK 4X4
    Thanks for the imput guys i might just go ahead and get the 885's if i can find another 100.00 or so.:rolleyes:
  16. Jun 22, 2012 at 4:55 PM
    Large
    Large Red
    I could have sworn I saw eibachs in that paragraph somewhere. Eibachs + bilsteins @ 85 + 1/4" spacer = 3" front lift (respectively) or you could do OME coils and 1/4" spacer for 3" front lift, you might have cv issues though. Also you'll might need aftermarket UCAs for alignment, I would just go with 2.5" front lift, it gives your cv's a better angle/ less wear & tear and the alignment is a hit or miss so you might not need UCAs.
  17. Jun 22, 2012 at 5:08 PM
    DevL
    DevL Well-Known Member
    No. Absolutely not if your spacer is on top of the coil assembly. This is as hard as a fact as can be. The only improvement will be if your current spacer makes your shocks compress to max before uptravel stops. 2.5" setting on 5100 is very rough. The spacer feels stock.
    If your spacer is a preload spacer the only difference is the 5100 shock valving. 5100 acts asa preload spacer.
  18. Jun 22, 2012 at 5:11 PM
    PETEREDGE
    PETER
    TEXAS
    2012 BAJA BLACK 4X4
    I think im just gona go with the 5100's up front set at 0.85 with 885's and buy the rear 5100's later on.If ive read right i should be at about 2 1/2 lift.
  19. Jun 22, 2012 at 5:13 PM
    OZ-T
    Peter North
    British Columbia
    885's and 5100's at 0 will give 2 1/2" lift
  20. Jun 22, 2012 at 5:18 PM
    PETEREDGE
    PETER
    TEXAS
    2012 BAJA BLACK 4X4
    Ok ill try that...now with that will the ride improve over the spacer.
