Will this transfer case fit? HELP!
Discussion in 'Technical Chat' started by kstaco, Mar 4, 2013.
  1. Mar 4, 2013 at 7:11 PM
    kstaco
    kstaco [OP] Well-Known Member
    Justin
    South Central, Ks
    Trd 4X4
    OME all 4 corners,AAL in rear
    I have a 2000 tacoma TRD 3.4 v6 w a man. tranny. The tranfer case is on its way out and think I may of found one after months of looking but not sure if it is the exact match to what is in my pickup. It is out of a 1999 tacoma 3.4 v6 man. tranny SR5 4x4. Any help would be great! Or if there is anything else I need to find out about the doner tacoma jus let me know.
  2. Mar 5, 2013 at 6:51 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    It should fit no problem (same engine same tranny) there where no changes.
    2001 got that crazy 4wd button but I know those where on automatics. I think all manuals are J transfer cases.
  3. Mar 5, 2013 at 8:39 AM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Same engine, same trans, it will fit.
    Push button was an option. You could get either push button or J-shift with any of the engine trans combos.
    It was never standard on any certain model.
  4. Mar 5, 2013 at 10:41 AM
    kstaco
    Justin
    South Central, Ks
    Trd 4X4
    Someone told me that some tacomas came w some kind of vaccum module on the back side of the front dif.. And that if it was there then it took a specific transfer case other than if the tacoma didnt have this (vacuum module)?????
  5. Mar 5, 2013 at 11:21 AM
    TherealScuba
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    If you have ADD your transfercase will have certain sensors near the top of the case at the shift rails.
    Those will need to be swapped over to the new transfercase.
  6. Mar 6, 2013 at 2:33 PM
    kstaco
    Justin
    South Central, Ks
    Trd 4X4
    Thanks for the info!
