Will this work for the 2011?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JBTWENTYTWO, May 27, 2014.
  1. May 27, 2014 at 7:46 PM
    JBTWENTYTWO
    JBTWENTYTWO [OP] Well-Known Member
    2011 Prerunner
    Cooper Discover STT tires 285/70/R17 (33s) Procomp 7032 matte black wheels 17x9 -6 offset. Front lift: Bilstein 5100 Adjustable Shocks set at 0. OME 885x coils. Rear lift: Bilstein 5100 shocks. 1.5 inch 3 leaf progressive. I still have stock UCAs but plan on getting aftermarket ones later. I ordered the shocks and coils from headstrong offroad and the 1.5 inch 3 leaf progressive from Wheelers Offroad. 50" Radius Light bar (From Sidetracked Offroad) Mounts from Relentless Fabrication.
    So I was looking at these LED grilles that Rigid Industries sells. They make the Grilles for the 2005-2010, but it says it will not fit the 2011 model. They also make the grille for 2012-2013 models, but it doesn't say that it won't fit a 2011. So basically my question is will the 2012-2013 grille fit the 2011 model?
    Here's the links if your curious!
    2005-2010 LED grille
    http://www.rigidindustries.com/led-grilles/40553
    2012-2013 LED grille
    http://www.rigidindustries.com/led-grilles/40552
  2. May 27, 2014 at 7:52 PM
    GuitarGuy91
    GuitarGuy91 Well-Known Member
    Stephen
    Glenville, NY
    16 TRD OffRoad Acc Cab (ordered)
    I would email them and ask. Because the 2012/2013 is a different style than the 2011 front end (correct me if I'm wrong).
  3. May 27, 2014 at 8:14 PM
    Fisherman559
    Fisherman559 Member
    That has to be a typo. 2010 & 2011 are the same
  4. May 28, 2014 at 8:26 AM
    ZEROPILOT
    ZEROPILOT Can't re-MEMBER
    ED
    SUNRISE,FLORIDA
    09 2.7 XTRA CAB 5 SPEED
    LARGER WHEELS. DIFFERENT STEREO. PUSH BAR. TAILGATE EXTENDER. WIPER MOD. TPMS LIGHT DELETE MOD.
    I'd make sure before I spent $500 for a grille insert.
  5. May 28, 2014 at 10:46 AM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Or you could get an off road light and mount it to the stock grill. Way cheaper.
