Will this work ?
Discussion in 'Wheels & Tires' started by GrayTacoLoaded, Dec 28, 2010.
  1. Dec 28, 2010 at 9:35 PM
    GrayTacoLoaded
    GrayTacoLoaded [OP] Member
    Jamie
    Coquitlam BC
    trd
    Size: 18x9 xd rockstars
    Offset: 0mm
    Backspacing: 5.00"
    Bolt Pattern: 6-139
    Tires 285/60/18
    Or 285/65/18
    Will this work with no trimming on a 2-3" lift without the tires sticking out past the flares 2"
    DC 4x4 long bed
  2. Dec 28, 2010 at 9:38 PM
    GrayTacoLoaded
    Jamie
    Coquitlam BC
    trd
  3. Dec 28, 2010 at 9:47 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    keep searching, but i believe your fine with that size, might have to trim cab mount, but with that backspacing you might be out of the fender wells just a tad.
  4. Dec 29, 2010 at 7:57 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    You can't run 285's with a 5" backspaced wheel. you need 4.5" or less.
    Even if you had a 4.5" backspaced wheel, the 285/65/18's will not fit without trimming.
    That being said, a lot of people are running 33's on their 3" lift. They just deal with trimming fender well plastic and possibly chopping the cab mount.
  5. Dec 29, 2010 at 8:09 AM
    Nightstr
    Nightstr Well-Known Member
    Felipe
    Sacramento CA
    05 prerunner sr5
    BLHM BLWM 3" TOUGH COUNTRY LIFT TRD SEAT COVERS THULE RACK M/T KM2 265/65/16
  6. Dec 29, 2010 at 1:19 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    the 285/60/18's will definatley fit. The 285/65/18's will probly require some trimming and might rub the upper control arm.
  7. Dec 29, 2010 at 1:22 PM
    TexasTacoma37
    With 5.0 backspacing? I doubt 285 width will fit.
  8. Dec 29, 2010 at 1:31 PM
    TacoSupreem
    Hayden
    Kentucky
    The 285/60/18's will work with that backspace. That tire is not gonna be as tall as the upper control arm. So as long as he stays below the upper control arm then he shouldnt have any rubbing issues. I believe Chris4x4 runs that size in a 5.71" backspace and it doesn't rub.
  9. Dec 29, 2010 at 1:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I think my wheels are a 5" back space....But I have no rubbing with the 285/60/18's,
