Will toyota cover a leaking sunroof at 67k miles?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TS4x4, Sep 6, 2022.
  1. Sep 6, 2022 at 10:32 AM
    TS4x4
    TS4x4 [OP] Well-Known Member
    2018 TRD Offroad
    Title. Got in my truck today after some heavy rain and noticed water on the drivers side floor mat. Drive straight out of my parking spot and a torrent of water came down from above the rear view mirror where the crawl control buttons are.
    Think the dealership will cover inspection and repair or am I SOL?
    Also could this possibly be the dreaded 3rd brake light?
    2018 trd OR
    Edit:
    Called my local dealer and they said $175 to just diagnose it (lol). HOWEVER, the guy who I got on the phone essentially told me to NOT bring it in and instead to "look up methods available" to see if the drain line is clogged first. Reading between the lines he seemed to be telling me that could be the culprit.
    Borracho Loco likes this.
  2. Sep 6, 2022 at 10:35 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Maybe. Ask the dealer.
  3. Sep 6, 2022 at 10:36 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    If your out of warranty your out of luck. And no its probably not the 3rd brake light as that is 5 feet away.
    Aqualoon and Borracho Loco like this.
  4. Sep 6, 2022 at 10:36 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    They might cover it with a tarp. Best bet is to take it to the dealer and hope it is the Third brake lamp and covered.
  5. Sep 6, 2022 at 10:37 AM
    TS4x4
    2018 TRD Offroad
    Yeah I just wasn't sure if the water could accumulate and flow forward through the headliner since I was parked on a slight decline. Just trying to cover all possibilities
  6. Sep 6, 2022 at 10:40 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Others can correct me if I'm wrong but at some point I've read threads saying that the sunroof has drains that can sometimes get clogged and cause the problem you are talking about. You might want to search clogged sunroof drains for the fix.
    TS4x4[OP], eurowner and Jofenech like this.
  7. Sep 6, 2022 at 10:40 AM
    5nahalf
    Erik
    Minnesota
    While it could, the angles of the headliner would make the water dump out well before it got to the front. Chances are you either have a plugged sunroof drain, or the sunroof was slightly open when parked.
  8. Sep 6, 2022 at 10:41 AM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    You are correct sir (for once!). OP, check your drain tubes/plug. Chances are, it's clogged and causing the backup to spill out into the cab of the truck. The best way to do this is by taking a can of compressed air and sticking the needle of the can into the drain line area. Then, let'er rip.
    TS4x4[OP] likes this.
  9. Sep 6, 2022 at 10:46 AM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    Borracho Loco[QUOTED] likes this.
  10. Sep 6, 2022 at 10:48 AM
    TS4x4
    2018 TRD Offroad
    I'll add this to my original post. Called my local dealer and they said $175 to just diagnose it (lol). HOWEVER, the guy who I got on the phone essentially told me to not do that and "look up methods available" to see if the drain line is clogged and unclog it. Reading between the lines he seemed to be telling me that could be the culprit.
  11. Sep 6, 2022 at 10:49 AM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    Just make sure you hold onto the spray tube when spraying. It can be a real bitch trying to get the spray tube out after it blows off the end of the nozzle.:burp:
  12. Sep 6, 2022 at 10:49 AM
    5nahalf
    Erik
    Minnesota
    If you go to clear the drains, be very careful if you use compressed air. It can and will blow the drain hoses off the nipples on the sunroof. Use wire and fish it through the hose.
  13. Sep 6, 2022 at 10:49 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Doubt it’d be covered unless you had an extended warranty
  14. Sep 6, 2022 at 10:50 AM
    TS4x4
    2018 TRD Offroad
    Shall do! Thanks for the advice
  15. Sep 6, 2022 at 10:52 AM
    5nahalf
    Erik
    Minnesota
  16. Sep 6, 2022 at 11:26 AM
    Buggin112
    Buggin112 Well-Known Member
    Portland, Oregon
    2022 Tacoma TRD Off-Road
    Or weed-wacker string. Worked great when the tubes on my explorer clogged. I tried the air first, and it just blew the line off and made it a much bigger project than what it started out as.
    5nahalf[QUOTED] likes this.
  17. Sep 6, 2022 at 11:39 AM
    geo8866
    geo8866 Unknown
    2019 TRD Sport cement
    I have had a sunroof on my last two trucks but had no clue there were drain tubes. Where would you find these drain tubes to check if they are clogged?
  18. Sep 6, 2022 at 11:42 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Based on previous threads here, it really depends on if you are a female and the service writer is a sexist pig. Warranty status doesn't matter.
    Speedfreak and musicisevil like this.
  19. Sep 6, 2022 at 11:50 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Think it will work for kidney stones? Compressed air sure didn't...
  20. Sep 6, 2022 at 11:54 AM
    Buggin112
    Portland, Oregon
    Usually in the front two corners and then run down the pillars by the windshield, and then drain somewhere under the vehicle between the door and the front fender.
    geo8866[QUOTED] likes this.
