Will TRD Pro (4Runner / Tundra) shift knob fit 2015 Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dzcustom, May 27, 2015.
  1. Jun 11, 2021 at 5:34 PM
    #41
    DifferenceMaker
    DifferenceMaker New Member
    Mat
    2013 Black Tacoma PreRunner
    My OEM shift knob that came standard on the truck never came lose. I recently replaced it with the TOYOTA PTR57-34141 TRD Shift Knob (which looks awesome by the way) and that was failing to tighten in the correct position. Once I added the plumbers tape the new knob tighter up about a full rotation earlier and isn’t loose at all.
  2. Jun 12, 2021 at 9:40 AM
    #42
    TRD2010SpeedwayBlue
    TRD2010SpeedwayBlue Well-Known Member
    Brandon
    2010 Speedway Blue TRD Offroad
    So you think i should put plumbers tape on my threads to get it to be tight?
    It never use to be like this which is weird
  3. Jun 14, 2021 at 7:53 AM
    #43
    DifferenceMaker
    Mat
    It worked great for my needs to solve for the loose TRD shift knob, I don’t see why it wouldn’t work to solve for the factory knob.
    The worse case if it doesn’t you simply remove the tape from the threads.
